best and most complete kit to do seat repair
my driver side rocks in back corner and has some front and back movement too
like to order a complete kit to do repair right
http://assets.suredone.com/1704/inve...seatrepair.jpg
this kit good?
this kit good?
The key to the repair is the replacement spacers/washers. It looks like this kit is using OEM materials - I'd avoid it and find a kit (or make them yourself) that has a harder material for the spacer such as steel or copper. There are a number of guys on the Forum that have made their own.
You won't know if you need the other bracket until after you get the seat apart. I did not need the bracket when I did my repair. Good luck.
this kit good?
this kit good?
Received 1,090 Likes
St. Jude Donor '13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
I did my seats and used this as a guide.
http://www.lieblweb.com/rockingseatfix.pdf
Cost me a whopping $3.
this kit good?
this kit good?
from the feel of my seat I think I to have a bracket issue more so then just washers. plus to think they are know to go maybe best i get updated version now and be done with the repair fully
Here's another thread about the back of the seat rocking - much more complicated than the washer fix.
https://www.corvetteforum.com/forums...post1588655287
Let us know how it comes out.
Pull your seat...very easy to do and look at the rear corner brackets....this link will solve your problems.
http://corvettepartscenter.com/drive...r-kit-1997-04/
https://www.youtube.com/watch?v=2vBEKWr6dgE
Went to Lyle's new shop in Sarasota last spring - at the time it was still under construction. Great guy - and knows his chit.
i guess
http://corvettepartscenter.com/drive...r-kit-1997-04/ is the best kit. do they sell 2 brackets instead of the one?
are there bushings oem or upgrades?
