Tire Pressures
Tire Pressures
I have Good Year F1 Eagle tires on my C5.
Front 245 45Z R17
Rear 275 40Z R18
I keep getting rear tires low. current tire pressures are front 35, rear 34. I had the sensors replaced, so i know they are good (I hope). So what is the correct tire pressures for these.
The door panel has different size tires with 30 Psi for front and back?
Front 245 45Z R17
Rear 275 40Z R18
Received 19,274 Likes
'20-'21-'22-'23-'24
Tire pressures are supposed to be 30 psi cold front and rear. And those tire sizes are the stock sizes for the coupe/vert. The Z06 had different size tires (265-40/ZR17 and 295-35/ZR18).
tire pressure
also what would be the procedure to reprogram them anyway....
thanks for responding...
tire pressure
OK, so now where do i get a round magnet as shown?
Age old question:
Inflate to the specs provided (usually on the door end panel) by the car maker?
Or, inflate the tire to the specs provided on the tire itself?
Different answer for OEM vs. non-OEM tire?
Is there a formula out there somewhere to determine the best pressure for your car and tires?
Age old question:
The tire pressure on the door is for OEM size wheels/tires. Any other sizes, and those OEM recommendations may not apply. I checked with Michelin Customer Service for what they recommended for the 265/35-18's & 305/30 -19's Pilot Super Sports I bought 3 years ago ; they recommended 35 psi front & rear for that setup.
Just had new Potenzas installed today (standard sizes) and was a little surprised on the way home: 31psi fronts/38psi rears (once warmed), numbers from sensors and confirmed with gauge once home.
Will adjust tomorrow when hot to 34 psi for all tires but curious why installer went with these pressures.
I always check/adjust before I drive home from the tire place.
I don't think any tire shop has ever set my pressures correct. Always check the first place I find on the way home.
I think you're wasting your time reprogramming. All that does is set the frequency for each sensor to match your car and the order you program determines it's position on the car. If you're getting readings, reprogramming won't make it read any different. You should not get low readings unless you drop below 25psi. I'd verify the actual pressure with an accurate gauge first. If you're using the dash gauge only, you won't know the actual pressure until you verify.
When you get "low pressure" what pressure does you dash show? You should never get that warning with any pressure over 25psi. If you're using a digital gauge to verify, make sure it's on psi. I'm not sure if it changes the tire pressure readouts, but also make sure your English/metric button is set to English.
Wouldn't the weight of the vehicle also come into play in determining the recommended tire pressure? For example, I wouldn't think a vehicle weighing 3,000 lbs would have the same recommended tire pressure as one weighing 4,000 lbs, with both having the same set of tires. The tires on the heavier vehicle has to support more weight, thus needing more air pressure in its tires than the lighter vehicle. Did Michelin Customer Service ask you what vehicle the tires were going on, or alternatively the weight of said vehicle?
When I contacted them, I told them my Make/Model/Year & the OEM size tires/recommended tire pressure. What you suggest makes sense, but I really don't know exactly how a manufacturer decides. I just wanted Michelin's input. I'm actually using 32-33 cold and I like the ride/fuel economy at that point. As far tread wear, the tires will probably age-out before the tread wears out.
Tire manufacturers and dealers will give you a recommended tire pressure designed for maximum tread life and long life of the tire - most of the time much higher than recommended on the door by the auto manufacturer, and in many times, up to the max or close to the max for the tire. The auto manufacturer on the other hand is giving you a tire pressure recommendation for quality of ride and maybe "handling". So it's always a compromise between the two, and with so many different tires, how can the auto manufacturer make a blanket recommendation for all the tires out there? What they are really telling you is the setup for the OEMs that come stock with the car. I personally like my tires inflated maybe 2 lbs. higher than the recommendation on the door, I like the ride and handling and tread life better. You pay your money and take your choice. Just because it is written on the label on the door, that does not make it law or infallible. Everyone is modifying tires, brakes, suspensions, engines, etc, so you adjust it as you feel best.
I called Michelin on Friday and asked them what tire pressures I should be running for Michelin Pilot Super Sport in the sizes on my car (345/30 -19 on 12.5" wide wheels, and 275/35 - 18 on 10.5" wheels). They asked the year, make and model of the car and entered the information into some type of calculator they have. Answer I got back was rear 29 and front 31.
Just about every car I've ever owned feels a bit crisper around town with 2PSI extra in front...I wasn't at all surprised that the C5 does too.
