Broke my Coolant Temp Sensor
Finally got around to installing my XS Power LT Headers over the long weekend. As I was finishing up I noticed that I broke the plastic piece on the CTS. The wire still plugs in it just doesn't lock on. How big of an issue is it to replace the CTS?
Received 19,223 Likes
'20-'21-'22-'23-'24
Good to know that it is an easy fix.
Super simple to replace - make sure you do it or you will get skewed read outs and not run properly - Happened to mine!
Thanks,Matt
Thanks,Matt
The sensor is approx $10 at Pep or Autozone - Borg Warner part is around $7.99
Borg Warner part #WT5132
Thanks,Matt
Thanks,Matt
How much coolant comes out during replacement?
You can even put a finger in the threaded hole after removing the old sensor and then slap in the new one -
You DO NOT put anything on the threads as they already are prepared from the factory -
Thanks,Matt
When it broke, I took it out to see what it was so I could order a new one... I already spilled a bunch of coolant in that process, so I hope that was about all that would come out
Got a got new one from NAPA and had it replaced in less than a minute with hardly any loss of coolant. Easy repair!
Now I just have to figure out why I have no power when I hook up my battery? I think I have a ground wire going to the starter instead of he block on the passenger side.
