BCM or ignition switch
Hello out there . I got a question about my BCM . Here is the short story . I had a heater core to bust in my 99 c5 manual transmission. The BCM got wet so I bought one on line . I started getting the pull key and service column lock .so I bought the lmc5 . It worked for a short while so they sent me another one called the five wire . I have talked to Richard many time and we have tried everything that he could think of . I did the relearn when I got the BCM but I didn't have my RPO codes put in simply cause none of the Chevy dealership will do it saying that it can't be reprogrammed . I don't know how true that is lol.look guys I love my car but right now every time I drive the car when I shut it off . I have to disconnect the battery to clear the code so the car will move . Could it also be the ignition switch losing connection or something. Any help please . It's a little embarrassing to open the hood everywhere I go too be able to drive off again.
Ok thanks but I know that the BCM is dry but I'm not sure what the LDCM or the RDCM . I did clean the buss connection when I changed the BCM . I'm sorry for asking the same questions about this I'm just trying to fix my car
OK, are you getting a code are you or are you talking about the DIC message?
I know you are getting a message. Does it prevent the car from being started and driven or just limit it to 2 mph?
I would like to see what 8VETTE7 thinks about this issue and the possible ignition switch relationship. If he does not see this Thread, PM him with a link to this Thread. He is the C5 Guru on CL issues.
The BCM RPO codes can be changed using any Tech 2. I have done it for several people. I would not recommend using those dealerships for any work on your car. Wish you were closer, I would be glad to do it for you. Surely someone in your area can do it. If not, and you want to drive over we can do it in about 5 minutes.
The issue with the door modules came out of left field. What are you trying to tell us?
Mr. Sam
PS: I remember your Thread on the heater issue.
Mr. Sam
Yes I'm getting codes and the car will shut off at the 2 mile speed . Someone named bill said to check my door modules and the buss connection. I really don't know what to look for other than broken wires or what . Now when I got the car to get the drivers side window to work I had to hit the door panel to make it work so I took it off and found the wire loom worked when I moved it to the side . So I taped it down so maybe I need to start looking there .
The BCM is not wet I replaced it the old one got wet and burned up . Richard asked if the used one I got came out of a auto or a manual car I not sure but my car is a manual I just got home so I'm going out to pull the code now and I will post them here shortly
Ok I wrote down the codes then cleared them and drove the car and checked it with the car running. And the list stayed the same . Here are the codes.
28 TCS- C1255H,C1281H
40BCM- B0502H,B0507H,B2482H,B2578H,B2583H,B2587 H,B2592H,B2723H
58SDM-B1001H,U1000H,U1040H,U1096H,U1064H
99HVAC-B0363HC,B0441HC,B446HC
AOLDCM-B2282H,B2284H,B1064H
RDCM-B2283H,B2285H,U1064H
SCM-B0851H
BO-RFA- U1096H,U1064H,C2120H-C
SCM-B0851H
SCM-B0851H
SCM-B0851H
