Replacing Crank Sensor question
2000 C5 had starter go bad & I am replacing. I'm thinking of replacing Crank Sensor while down there. Is anything needed as far as a relearn for sensor replacement or is it just remove the wire, 1 bolt, pull out old , insert new & that's it? I was getting a intermittent code P 1637 both H & than H C when running. I found really loose connection at starter that crumbled in my hand when checking it. Plastic that held batt bolt cable to solenoid probably got heat destroyed from LT headers after 11 years.
