wheel weights on new black wheels
guys I need some advice on stick on weights for my new reproduction c7 wheels for my c5. the wheels are black and I am worried about the stick on weights to balance them the goodyear man said he could put the weights on the edge of the inside of the wheel called a static balance but he said it might not be perfect. has anyone done this before? also the new wheels are tpms compatible so will my tpms give me any problems by changing them to a new wheel? one dealer told me I would need new valve stems and they will all need re-calibrated which would cost $35 extra for each wheel. please tell me what you guys think. thanx
The weights placed inboard on the barrels are not a problem, even on the edge. You won't need new valve stems as they are integral to the TPM sensors. You can reuse those unless they are the originals. They're good for about 10 years. If they aren't placed in the same corner of the car that they came off from, they'll need to be reprogrammed. You can do that yourself in 2 minutes. Instructions are in your owner's manual.
I worked in a shop and still go back there to work on my car so I did my own, I used a standard hunter 9700 like most of the industry. They balance fine(c5 z06 repos), I also painted the WWs black with touch up paint. I elected not to reuses the TPMS sensors and went with black valve stems, if I cannot figure out if my tire is going flat I should not be driving a car. Also on a previous car/ repo wheels I have had the TPMS nuts damage the finish on the wheels when you tighten them down, so I avoid them, and they do not match. If they have a road force balancer, ask them to road force them, you will get a good balance if they know what they are doing.
But IMHO, being able to detect a slow leak with one button before it becomes obvious is worth having valve stems that don't match the wheels.
You actually do that? I check my tires maybe once a month aside from just glancing at them to determine one isn't completely flat. Tpms to me is for the idiots who would drive around on 12 psi if a light didn't tell them not to.
But I've had enough tires over the years with 1PSI/day slow leaks to appreciate being able to detect that condition without a gauge before it becomes a problem.
Didn't know the c5 had tpms when i boufht it nor did I care...pulled it out of my 370z as well, working in the industry I've seen more faults in these systems than I care to worry about or deal with. Plus I've only had one tire issue thus far...and if I have one I have one....
Who said anything about waiting for a tire to go completely flat? If you can tell a tire is down 4-5PSI by eyeball, good on ya: I can't.
Received 1,090 Likes
St. Jude Donor '13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
Black wheels, ask the shop to spray the wheel weights black so they are less noticeable.
Or bring a can of paint yourself!!
Received 19,293 Likes
'20-'21-'22-'23-'24
My wheels are balanced the same way that your Goodyear guy mentions (to the inside of the wheel) and the balance is perfect. A competent tire tech can get it right.
As far as the tire pressure sensors go, if the wheels you bought will indeed accept factory sensors, then all you need to do is swap the sensors to the same location (i.e. right front existing wheel to right front new wheel) and you'll be set to go. When I installed sensors, I went ahead and ordered new attachment nuts for the sensors, but I would suppose you could do without new ones if you want. I would certainly check the O-rings on each sensor and replace if they look bad.
