Service this..service that. Do I need to worry?
Just picked up a 99' vert' with 112k miles. Got the dreaded "Service active handling, ABS, and traction control". Did the research and pulled the codes. I'm showing, among others, is a TCS 1226 as a history. Only current code is B2172 which has to do with the power seat. Should I be looking for any codes that could indicate a major problem like I've read about? The lights go off and stay off (so far), when I quickly restart the car.
Thanx for that informative reply. Disconnecting the wire is located near the brake line, correct? Don't want to drive without the nannies so I'll get her fixed. Thanx!
