***New Cree LED turn signal bulb from Radioflyer Innovations***
Old 07-20-2015, 09:34 AM
TheRadioFlyer
Supporting Vendor
TheRadioFlyer's Avatar
Default ***New Cree LED turn signal bulb from Radioflyer Innovations***
Until now, if you wanted Cree LEDs in your DRL/turn signal housing, you needed to modify the housing to accept the longer bulbs....
Not anymore. Radioflyer innovations has just received a shipment of the new Cree 25w short LED bulbs that will fit in the factory mounting location without any modifications.
The bulb uses the same Cree LEDs as our 30w version so you can expect the same pure color hue to the turn signal. The aluminum heat sink not only looks cool, but keeps the LEDs cool too.
Add a hyperflash harness to your cree bulbs at a discount off the normal hyperflash harness price.
It gets better! Through the end of July, when you order a set of the Cree turn signal bulbs and hyperflash harness you can use the coupon code "C5CreeTurn" to get $20 off your order.
Bulbs and hyperflash harnesses are in stock and ready to ship the next business day!
Order here:
http://www.shop.radioflyerinnovation...rvette-091.htm
Old 07-22-2015, 07:39 AM
TheRadioFlyer
Supporting Vendor
bump
Quick Reply: ***New Cree LED turn signal bulb from Radioflyer Innovations***
