Stainless Steel Headers Made In USA for Under $850 Shipped @ Hinson Motorsports
Former Vendor
HINSON Motorsports is proud to offer the only ceramic coated stainless steel header built in the America under $850.00. The HINSON Motorsports C5 header systems are proudly built in the USA from stainless steel and then ceramic coated for lower under hood temperatures. Our ceramic coated stainless steel headers use mandrel bent 1 7/8" tubing and 3/8" flanges for a precision fit and finish.
Features
Stainless Steel Construction and High Temp Ceramic Coating
Easy installation
1 7/8" Mandrel Bent Tubing for peak exhaust flow
3" Collectors
Lower under hood temperatures than non-ceramic coated headers
Slip fit collector for easy connection to a performance X-pipe
Ceramic Coated X-pipe for reduced center console temperatures
Direct fit application for all C5's- No fabrication required.
Includes
Ceramic Coated Stainless Steel Headers
Ceramic Coated Aluminized Steel Header Extensions
Ceramic Coated Aluminized Steel X-pipe
Aluminized Steel Rear Axle Back Connection Pipes
O2 Sensor Wire Extensions (x2) $50 value
Clamps
Installed prior to ceramic coating
In stock and currently being ceramic coated. Anticipated ship date of July 27 2015.
Received 19,219 Likes
'20-'21-'22-'23-'24
For a basically stock C5 (only mods are a Blackwing and Corsa Indy Pace Car catback), is a set of 1 7/8" headers the right size or would 1 3/4" headers be better? If the latter, do you plan to expand you offerings to include the 1 3/4" headers?
bajapointe (10-20-2015)
'20-'21-'22-'23-'24
Bump up for hopefully an answer from the vendor.
Former Vendor
See answer above.
Sorry for some reason this didn't show up on my thread history. Had to go digging for it to find it this morning.
Former Vendor
Here is a video of a customers C5 that we installed our New HINSON C5 ceramic coated headers on as well as our new HINSON C5 short throw shifter, and our HINSON High-Roller camshaft. Check it out.
Former Vendor
We couldn't agree with you more. This cam is truly a very well rounded cam that provides great power and sound without sacrificing drivability. We are slowly putting more of our cams on the site like this one. This one is our High-Roller cam. We have partnered with Bullet Racing to proved excellent power and reliability to our customers. If your int he market for a cam give us a call, we will gladly fix you up with a custom grind for your application.
Former Vendor
[QUOTE=HinsonSuperCars;1590238804]In every case a 1 7/8" header is going to make more power than a 1 3/4", which is why we made the 1 7'8" headers. Why pay the same money for less. We do not have any plans to make a 1 3/4". There are tons of test and threads that have addressed this directly over the years and proven this.
[/QUO
That is true up top, but for low modded cars (stock or light cam, no heads or intake work), the 1 3/4 headers will produce and yield better mid range torque.
Once you start adding more power mods then yes 1 7/8 s are better.
BTW, thanks for making quality headers affordable. Will be nice to see how they compare on the dynos to the competitors.
[/QUO
thanks for your time
Former Vendor
awesome thanks! i have a few questions for you folks, will there be high flow cats offered? do you have any dyno tests of before and after the header install on stock and modified engines? and last but not least, how much hp&tq can be gained on a stock LS1 with your cam and header upgrade, ballpark figure is fine.
Well we have a set in stock with your name on them. Thanks for the vote of confidence.
See above answer.
