Not accelerating in 6th gear
I did a road test for a 2002 M6 with only 26k miles. I was cruising at 60 mph in 6th gear and tried to accelerate but it wouldn't. No strange noise, no increase in rpm, no slow down, had to retro in 5th. Tried twice. I thought it's because I am not familiar with the car. I will have a pre- purchase inspection done. Any comments? Thanks.
6th is not really meant for acceleration but you should be able to feel it. When you hear about C5s hitting 185 they are typically doing so in 5th. 6th is more of an overdrive - but again there should be a feeling of acceleration. Can only provide my experience - can't help with the problem. Good luck.
MTL01 (09-21-2015)
It wouldn't accelerate at all or just very slowly? Per the other reply 6th is for mileage only. Even top speed is done in 5th.
I very rarely use 6th.
MTL01 (09-21-2015)
6th feels like you are trying to move a locomotive or freighter but there is a gradual acceleration. If I'm going 60 or 70 and really need to move I'll actually down shift to 4th.
Shakeydeal (09-22-2015)
Received 19,292 Likes
'20-'21-'22-'23-'24
And I've not heard about stock C5s hitting 185 mph - top speed for the coupe per GM was 175 mph. The Z06 was rated at 171 mph.
MTL01 (09-22-2015)
at 60mph you were probably around 1200rpm in 6th gear.thats barely above idle.try accelerating from about 1800 rpm it should go a little better but the 6th gear is very low and there isn't much torque in that rpm range.
think of it like pedaling a 10 speed bike.if you got on a bike that was barely moving,and were in 10th gear,you would have a hard time trying to pedal and get going.but the faster the bike was rolling(more rpms) the easier it would be to pedal.
MTL01 (09-22-2015)
Personally I never/rarely use 6th. It's just there for highway mileage. The only time I've used it was when I was cruising at 80+ mph. Anywhere below that, I stay in 5th.
MTL01 (09-22-2015)
Received 1,261 Likes
you should still be able to pass most slow highway drivers without having to drop a gear but if you want to pass faster then going to 5th, 4th, or even 3rd will definitely help... I usually drive between 70-80 on the highway if I'm able to so that will make passing in 6th a little easier due to the higher rpm and if your car is making enough power it can actually accelerate in 6th at wot
MTL01 (09-22-2015)
Mister
When I had a six speed C5, sixth gear did not provide much acceleration - but it did provide some. Dropping into 5th or 4th made a noticeable difference.
1/4 mile/AutoX
Ha.
Mine at around 63 to 67. Never enjoyed it though. Less gas pedal would keep it a bit smooth. Other than that I live with 4th and 5th on the highway until I feel as if I need to go to 6th. Cruise on the highway doing 65mph on 6th and 1500rpm makes me go to 5th do 80mph then downshift to 4th doing 1something and then to 6th.
Received 2,706 Likes
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16'-'17-‘18-'19-'20-'21-'22-
'23-'24
I'm only in the 6th at 65+ on flat ground.
If you stomped on an auto at 60mph it would downshift...automatlically
The manual relies on the pilot to perform the downshift....manually
That's the beauty of the manual, you pick the gear you want when you want it. Provided the #! $& CAGS has been eliminated.
MTL01 (09-22-2015)
