need advice on c6 zo6 tire size on my c5 base
Picking up some c6 zo6 wheels for my 2000 model base series. I need some new tires and wanting suggestions for the proper size to fit best with the c6 zo6 wheels and 3/16 spacers.
mrr23 (10-06-2015)
Factory GM C6 z06 wheels in C6 sizes (18-19)?
Or repro C6 Z06 wheels in C5 sizes?
If they are factory C6 sizes you can run the factory sizes on them, I would NOT run the spacers, they will already stick out quite a bit.
mrr23 (10-06-2015)
They are factory zo6 c6. I was under the impression you had to run spacer on the c5 to keep them from rubbing
mrr23 (10-06-2015)
St. Jude Donor '15
as i said on facebook, I run a 1/8" spacer to keep them from rubbing the inner liner. I run 245/40-18 front and 325/30-19 rear. You can run the 275/35-18 for the front, if you want wider.
http://www.corvetteflorida.com/forum...d.php?t=102573
jonrobinson84 (10-06-2015)
jonrobinson84 (10-07-2015)
2017 Corvette of Year Finalist
2016 C5 of the Year
mrr23 (10-07-2015)
mrr23 (10-07-2015)
mrr23 (10-07-2015)
i am torn on this i see some pics that look like the tires stick out a lot when you mount c6 z06 rims on a c5 vette..but when i have seen them in person they really don't look bad at all...so i guess its just preference really
