How To Videos
Platinum Supporting Vendor
How To Videos
Hello all,
We are beginning the thought process on developing a series of How To videos that will be thorough, detailed, and as clear as possible for Corvette owners of any experience level! We have a number of ideas on what kind of videos we will be doing, but we also want to hear straight from you guys on what you would like to see!
I want to hear every suggestion you've got! Think back on some projects you've worked on where you would have liked having a step by step video along the way! Nothing is too simple or too complicated. We've thought about doing everything from oil changes, to sway bar adjustments, to interior dyeing, to seat cover removal and installation, and much more. We want to offer a wide array of videos to help beginners and experts alike!
What kind of How To videos do you want to see?
-Nick
-Nick
__________________
Pursue Your Passion Here ®
Mid America Motorworks
454 Big Block Dr
Effingham, IL 62401
www.mamotorworks.com
(800) 500-1500
Family Owned Since 1974!
454 Big Block Dr
Effingham, IL 62401
(800) 500-1500
The following 7 users liked this post by Mid America Motorworks:
Big Vig (07-11-2016),
black match box (10-09-2015),
mpride (10-15-2015),
mrr23 (10-13-2015),
Pounder (07-10-2016),
and 2 others liked this post.
Replace sun visors
Replace EBCM
Change pulleys, hoses and belts
Cleaning MAF sensor and throttle body
Changing plugs and plug wires
Drain and replace coolant
Brake job.
Replace EBCM
Brake job.
The following 2 users liked this post by JR-01:
Mid America Motorworks (10-07-2015),
mrr23 (10-13-2015)
mrr23 (10-13-2015)
Radiator removal and cleaning...
HARMONIC DAMPER replacement....
LOWERING on stock bolts...
VARARAM installation...
Checking/Adding/Changing transmission fluid in an AUTOMATIC...
EMERGENCY brake adjustments...
HEAD LIGHT gear replacement...
SHOCK replacement
SHOCK replacement
-Nick
How to ajust windows after replacing reg.
The following 2 users liked this post by Vanover:
Mid America Motorworks (10-08-2015),
mrr23 (10-13-2015)
How to use a Voltage Meter to test alternator output...
How to use a Voltage Meter to test battery voltage...
How to BURP your coolant system...
The following 2 users liked this post by 73Corvette:
mrr23 (10-13-2015)
How to Remove/Replace Automatic Transmission and Engine in your garage.
How to Remove/Replace Harmonic Balancer in your garage.
The following 2 users liked this post by Choreo:
mrr23 (10-13-2015)
The following 3 users liked this post by Crosis:
Here's a common problem that could sure use some video help.
How to test for, find, and eliminate parasitic battery drain on C5s. Could also be for the younger brothers too !!
The following 2 users liked this post by CactusCat:
mrr23 (10-13-2015)
The following 3 users liked this post by SuperTom:
The following 2 users liked this post by Ceedub53:
mrr23 (10-13-2015)
Received 19,234 Likes
'20-'21-'22-'23-'24
How to repair a leaking rear differential seal.
Headlight aim adjustment.
Gauge bezel installation.
Aftermarket shifter installation.
The following 2 users liked this post by Vetteman Jack:
mrr23 (10-13-2015)
mrr23 (10-13-2015)
Thanks for all the great suggestions guys! Crosis has a point! I wish I could guarantee we'll be able to do every single suggestion, but who knows! We have winter coming up, so we'll have some time on our hands without any shows going on!
-Nick
-Nick
mrr23 (10-13-2015)
I appreciate your desire to do this. I have a recommendation. Once you decide what you want to do for the first several ones post a Thread for each one. Let us provide you with existing links on videos, Threads or input on the topic. You could end up using that info in developing the video. I have done several extensive write-ups on a number of issues like replacing the electrochromatic mirror and parasitic drain. I also have hundreds of links on virtually every topic related to the C5.
You might even decide some existing material is good enough and you just provide a link to it so you can use your money for providing information that does not exist to the level you desire. This Forum only has a few sticky Threads to try and address such issues. Some are so long you could spend a day going thru them. You could end up being a great resource to owners by providing videos or other resources, or both.
Good luck, it's a lot for you chew on.
Mr. Sam
Mr. Sam
The following 2 users liked this post by dadaroo:
mrr23 (10-13-2015)
Mr. Sam
Mr. Sam
When I sit here at my desk and look out at everyone else on this floor, I see so many gold mines of information sitting in the heads of many of the guys up here. We have so many knowledgeable Corvette guys up here and I can't wait to start getting them involved with making the videos and seeing them do their magic as we film!
-Nick
mrr23 (10-13-2015)
The following 2 users liked this post by DRAFT1:
mrr23 (10-13-2015)
This is a F-A-B-U-L-O-U-S IDEA
After just returning from a 756 mile trip last week to Bowling Green Ky. I would love to see a video detailing; "How To Soundproof And Reduce The Noise Level In Your Vette"
The following 3 users liked this post by Glasact:
