Front suspension questions - Converting 98 Camaro to C5 spindles and upper a arms
I am working on my build of a 98 Camaro drag car. It is going to keep the double wishbone front, but I am using the C5 uppper a arm and spindles. This should loose me quite a bit of weight.
Couple questions
1. What should the anti dive be set? I think I got it mocked up pretty close to where it needs to be, but I would love some input on it.
2. From what I have read, the C5 caliper and the LS1 Camaro caliper are interchangable. I mounted one of my calipers. I was hoping that only the caliper bracket was different, but I think the mounting position is what is different. I think I have 12" rotors. The pad seems to line up off center of the rotor to the outside. What size are the Corvette rotors?
Couple questions
