Scraping front-bottom :(
2) Most parking lots, including where I work, have a small concrete barrier several inches high at the front end. I have never before owned a car that is so low to the ground. Our C5 Corvettes have a downward protruding air dam that scrapes these, which for me is more of an embarrassment if somebody is nearby.
Does anyone have any parking technique recommendations to facilitate stopping short of the concrete barrier? Perhaps the Heads Up Display location relative to the street, can be used in some fashion to guide me?
Any advice would be welcome, except for "Just be more careful and don't scrape your car, moron!"
Received 19,305 Likes
'20-'21-'22-'23-'24
The front air dams are just made of plastic and are really designed to be flexible should any scraping occur. With the car being so low, it's hard not to scrape the air dam at some point and when it gets to looking bad, they are not all that expensive to replace. One technique that you can use is to approach the object at an angle - sometimes that minimizes the amount of contact the air dam will have and thereby reduce the scraping noise.
Welcome aboard!
Two suggestions in order of difficulty (although none of them require considerable effort):
1) Fangs
2) Curb Alert
I installed both of them and I'm very satisfied.
1) Fangs
2) Curb Alert
I took the side dams OFF and trimmed the middle one about 2"... NO my car doesn't over heat...
scrapings
I would just start stopping short when pulling up to concrete barriers. You will soon learn where your front end is when parking. Enjoy your new ride!
St. Jude Donor '13, '15
The front end is longer than you think. Learn to stop sooner and it's a free mod. I'll sometimes use the reflection in the car next to me to help see when I am getting close.
All of my cars are lowered, and I always back into parking spots. If someone has to wait, too bad. It is safer pulling out since you have much better vision when pulling out. My Son's do the same thing, only the Wife is stubborn and doesn't back in.
I do have fangs installed, more for protection on the occasional mega high speed bump....
2018 C5 of Year Winner
Back in if you can.
Angled approach.
If I were to get to close pulling in one of these parking spots I'd hit my bumper I've gotten pretty good at gauging distance as I can't afford constant bumper replacement and I can't imagine raising her back up
Angled approach.
I reviewed the Curb Alert web site and I do like it. That would be a nice weekend project for me in December once it cools down here in Miami.
Cannot always back in, here in Miami. Parking spaces tend to be very narrow, and frankly I'm not that good at backing in to spaces that are wide.
I'd have to position the Curb Alert sensor in the rear of the car!
The curb alert may help with not pulling up too close to barriers, but it's NOT going to help with the AIR DAMS rubbing when your going thru a dip or going up an incline that's fairly steep... again removing the side dams and trimming the middle dam is a viable option if you don't want them scraping... adding the fangs is also a good idea.
IF your driving your car 150 MPH then you might want to reinstall the side air dams to keep the air drag off of your front tires and reduce lift under the car... other wise they DO NOTHING else for your cars performance for normal driving... trimming the middle air dam hasn't added 1 degree to the operating temps of our car... just sayin.
I bought 2 sets thinking I'd ruin my 1st set pretty quickly but the dam things are incredibly durable.
Not sure what happened to the OP, but I do have a brand new, still in the package set of Fangs that will be posted later today in the C5 Parts for Sale section.
$45 shipped anywhere in the US.
PM me and save me the trouble of listing them...
