New Paint for 2003 C5
What should I expect to pay for new paint job - not custom show car, but professional job equal to factory paint. Would appreciate some references in Northern Virginia. thanks.
Received 19,305 Likes
'20-'21-'22-'23-'24
A cost of $4-5K for a decent paint job would be about right but could go higher depending on the shop and labor rates.
I would say anywhere from $5K to $10K for a good quality paint job. Most of the cost will be labor: prep such as sanding and any body work. That is a very important process for getting a good spray job. Good paint shops will do a lot of hand sanding to insure a proper base.
The sealer, primer and base coat and then the clear coat cost can vary depending on the paint brands, the amount that will be used, and possibly even the color.
After the car is out of the paint booth, there is more labor; color sanding, polishing, and final cleanup.
The best thing to do is to get estimates from a number of body shops. They should provide you with pricing details, not just a single fee.
fredmills (11-17-2015)
2018 C5 of Year Finalist
St. Jude Donor '14,'18
Painting the car the same color doesn't require dis-assembly. You're not looking for custom and maybe it's a driver so don't invest more than necessary. Check with a Chevy dealer with a good body shop.
How bad is paint now? Costs will very with quality, I would not consider a shop without a good recommendation from a known source! They can really screw up your car, be careful, a redo could cost way more! Good luck
I heard they did a fairly good job. You took your car to them body worked, sanded and masked off and they just sprayed it. It was extra if they did more than sprayed it.
Oldtimer
for 30 bucks it wasn't horrible but overspray wasn't uncommon as were runs. But again, for 30 bucks... you got what you needed - a car that looked somewhat reasonable at least.
Received 1,609 Likes
St. Jude Donor '16-'17,'22,'24
Many years ago I bought a 64 Buick Skylark convertible as a DD to stop putting so many miles on my 69 C3. The Buick ran great and had a really nice interior but the paint had crazed badly. We sanded it, removed almost all of the chrome and old Earl painted it metallic burgundy for around $50. Came out great. The guys I worked with were surprised at how good it came out. Still, wouldn't have brought a Vette there. But for a beater, it was great.
I've got an estimate from a vette only collision shop just to take off hood and both head light covers to get rid of some minor rock chips, scrapes and scratches. $1000.
Honestly, unless there is some sort of emotional attachment, you are better off IMO selling your current (needs a paint job) car. Then take those proceeds, and buy a newer, lower mileage car not in need of a paint job. If you factor in the cost of a professional paint job, I'm betting you'd come out ahead financially by taking this route. And, IMO no matter how nice a re-spray is, it still de-values a car compared to a factory paint job. Any knowledgeable buyer will always have the question in his or her mind as to "why" was the car repainted.
My 2 cents.
My 2 cents.
