audio install question!
im hooking up my hu and need a spot for my illumination wire.. since I have a 04z my car is not the same wire diagram as other years. last do I need to hook up the green parking brake wire? thanks
Received 19,291 Likes
'20-'21-'22-'23-'24
If you don't get a response to your question, give Dennis at Double D Mods a call and ask his advice. He is very knowledgeable on audio installs.
I try to post in the audio section but it takes awhile to get any feed back. right now I am working on my car so I hope to hear something soon...lol
I believe you splice into the cream color wire on the HVAC unit. Are you installing a double din? If so you may want to ground the parking wire if say you were installing a Kenwood so you could watch video while driving.
I have it figured out thanks.. but I have question about rca cables is it just hype or they really do make a difference cheap compared to expensive?
