Kenwood KDC-X500 Single Din Radio Package $179.99 BT- Music Streaming - Pandora
Former Vendor
C5 Kenwood KDC-X500 Single Din Package
ALL NEW MODEL FOR 2016!
Now shipping!
$179.99
Your kit will include
1- Kenwood KDC-X500 single din radio
1- 1.5 to 1.0 din dash kit
1- roemvet1
1- GM antenna adapter
Product Details
Kenwood eXcelon CD Receiver With Built-In Bluetooth - KDC-X500
Key Features:
TDF(Theft Deterrent Faceplate)
Drive Change
Maximum Output Power : 50W x 4 (MOSFET Power IC)
Kenwood sound reconstruction, restores musical to compressed music
MP3/WMA/AAC/WAV/FLAC Files Playback with ID-3 Tag Display
Android Rapid Charge
Multi language(English, Spanish)
Dual Phone Connection
Wireless Music Browsing
Features:
General Features
CD Door / Cover
13 Digit 1.5Line LCD Display
Rotary Encoder and Direct Key (TEL) for easy operation
Digital Clock (12H)
Variable Color Illumination
Dimmer Control Function (Manual/Set by timer)
Audio Features
Front AUX & USB Interface with slide protection cover
3 Preout (4V)
Equalizer (13Band)
Drive EQ
Subwoofer Level Adjustable
System Q
Bass Boost
Loudness
Built-in LPF/HPF
Stage EQ
USB Features
MP3, WMA, AAC, WAV, FLAC Decoder with ID-3 Tag Display
iPod/iPhone Direct Connection with Optional cable*1
iPod Skip/2 Speed Search Function
Pandora / iHeart Radio App Ready (iPhone App)
Drive Change (For Android or Card Reader)
Android Music Playback
*1: KCA-iP102: 30-pin type, KCA-iP103: Lightning type
Tuner Features
Sirius XM Ready
Backup Memory for Tuner Preset
FM/AM 24 Station Presets (18FM, 6AM)
RBDS with Radio Text
AME (Automatic Memory Entry)
Up/Down Seek Tuning
FM Stereo/Mono Selector
CD Features
MP3, WMA, AAC Decoder with ID-3 Tag Display
Folder Name Manual Search Function without Stopping Audio-play
0-bit Mute
CD Text Ready
CD-R/CD-RW Compatible
Random/Repeat Play
External Media Control Features
Bluetooth Built-in (Hands-Free Profile / A2DP/ AVRCP1.5/ Voice Control / AptX)
Pandora / iHeart Radio App Ready (Android App : A2DP/SPP/Multi Profile)
Rear Wired BT Microphone included
OEM Remote Interface
Specifications:
FM
Frequency Range(Frequency step): 87.9MHz - 107.9MHz (200kHz)
Usable Sensitivity S/N:26dB: 8.2dBf (0.71μV/75 Ohms)
Quieting Sensitivity DIN S/N 46dB: 17.2dBf (2.0μV/75 Ohms)
Frequency Response (±3.0dB): 30Hz-15kHz
S/N: 64.0dB(MONO)
Stereo Separation: 40dB(1kHz)
AM
Frequency Range (Frequency step): 530kHz - 1700kHz (10kHz)
Usable Sensitivity S/N:20dB: 29dBμ (28.2μv)
CD
Laser Diode: GaAlAs
Digital Filter (D/A): 8 Times OverSampling
Spindle Speed: 500~200rpm (CLV)
Wow & Flutter: Below Measurable Limit
Frequency Response: 20Hz-20kHz(±1dB)
Total Harmonic Distortion: 0.01%(1kHz)
S/N Ratio (dB): 110dB(1kHz)
Dynamic Range: 90dB
Channel Separation: 85dB
MP3 Decode: Compliant with MPEG-1/2 Audio Layer-3
WMA Decode: Compliant with WINDOWS MEDIA AUDIO
AAC Decode: AAC-LC ".aac" files
Audio
Preout Level(mV)/Load-Unbalanced: 4000mV/10k Ohms(CD)
Preout Impedance (Ohms): ≦600 Ohms
Speaker Impedance (Ohms): 4-8 Ohms
USB I/F
USB: USB 1.1 / 2.0 Full speed
File System: FAT12 / 16 / 32
Maximum Supply Current: DC5V(DC logo) 1.5A
WMA Decode: Compliant with Windows Media Audio
WAV Decode: Linear-PCM
FLAC Decode: FLAC file (Up to 48kHz/16bit)
AUX Input
Frequency Response: 20Hz~20KHz ±3dB
Input Maximum Voltage: 1000mV
Input Impedance: 30K Ohms
AMP
Maximum Power: 50w x 4
Full Bandwidth Power (at less than 1%THD): 22w x 4
TONE
Band 1: 62.5Hz ±9dB
Band 2: 100Hz ±9dB
Band 3:160Hz ±9dB
Band 4: 250Hz ±9dB
Band 5: 400Hz ±9dB
Band 6: 630Hz ±9dB
Band 7: 1kHz ±9dB
Band 8: 1.6kHz ±9dB
Band 9: 2.5kHz ±9dB
Band 10: 4kHz ±9dB
Band 11: 6.3kHz ±9dB
Band 12: 10kHz ±9dB
Band 13: 16kHz ±9dB
Bluetooth
Version: Bluetooth V2.1+EDR /Bluetooth 3.0
Frequency Range: 2.402-2.480GHz
Output Power: +4dBm(MAX)、0dBm(AVE)Power Class 2
Maximum Communication Range: Line of sight approx.10m(32.8ft)
Profile:
HFP(Hands Free Profile)
SPP(Serial Port Profile)
PBAP(Phonebook Access Profile)
A2DP(Advanced Audio Distribution Profile)
AVRCP(Audio/Video Remote Control Profile)
General
Operating voltage (10.5~16v allowable): 14.4V
Maximum Current Consumption: 10A
Faceplate: TDF(Theft Deterrent Faceplate)
Operational Temperature Range: -10°C to +60°C
Approximate Dimensions:
Width: 7-3/16"
Height: 2-1/8"
Depth: 6-1/4"
Approximate Weight:
Unit: 2.87 lbs
Shipping: 5 lbs
NCM Lifetime Member
Received 3,926 Likes
St. Jude Donor '18-'19-'20-'21-'22-'23-'24
Looking forward to this upgrade. Thanks Dennis!
Dennis,
What has to be done insofar as the mounting of the unit into the console? Do you take out the factory radio's bracket and replace it, or ????????
Former Vendor
NCM Lifetime Member
Just got the new stereo installed and it is really nice. Thanks for all your help Dennis!
Now if I can just learn how everything works on it
Former Vendor
Double D. Been looking at doing a double DIN but really, in my old 99, this looks like a great deal especially with the BT, aux in, iphone and Droid charging etc. and since I use my Droid for navigation, it's all good in that realm.
So, my question are:
1) still available?
2) plug and play for the most part?
3) any issues with the stock Bose speakers?
4) does it come with "*1: KCA-iP102: 30-pin type, KCA-iP103: Lightning type" ? If not, how much to add it to the package, if you have it?
5) anything else I should know since my family has both iphones and Droids?
sure I have more but all I can come up with at this point. Had a Kenwood BT in my last play car (2001 BMW Z3 3.0) and loved it. This updated unit has me excited actually if it's a simple install...heck, even if it's not, still be excited to have aux etc. vs the standard OEM deck.
1) still available?
Former Vendor
1) still available? YES
2) plug and play for the most part?You will need to connect 1 wire into the car
3) any issues with the stock Bose speakers?no this is what the roemvet1 portion of th epackages covers
4) does it come with "*1: KCA-iP102: 30-pin type, KCA-iP103: Lightning type" ? If not, how much to add it to the package, if you have it?no they are optional but you really dont needthem as just use the cable that comes with your phone for charging
nope. Works with both
Dennis
Dennis,
2 more questions for now... 99 Vette
1) where are we mounting the BT mic's nowadays ? Been researching the site but can't find a definite place to mount. One post said on top of the steering wheel and I remember on my Z3, it was mounted up high near the pivot area of the driver's visor. Any suggestions please?
2) confirming phone calls will be heard via the stock car speakers ?
Thanks again for the quick response and shipment of the radio
Former Vendor
Dennis,
I usually mount them in upper corner of driver side apillar
yes
yes
Any links for the install Dennis ? My stock radio is stuck in the opening...do I pull harder lol or ? Thanks...
Still searching on the forums for how to's'
Will look harder for directions and where did people put that wiring harness etc....
NCM Lifetime Member
I just installed this stereo in my 03 Z and would be happy to help answer any questions you have. I sent you a PM with contact info.
civi (02-28-2016)
Thank you...
I only had about 2 hours of time this morning (after 1am) to tinker and didn't want to call you at that time
I figured it out but wanted to publicly thank you for your offer
Any other issues, I will contact you
