Can We Talk About LED 9006 Bulbs?
Well, I've been thinking about LED headlights lately. There are a lot of different bulbs online, but I don't see anybody trying them in headlights on C5s, and I'm curious as to why?
I'm hoping I can learn something in this thread, and that maybe others can as well.
I don't drive much as night, so it's not a bid deal-it's more of a curiosity thing.
I started thinking about it after installing Cree LEDs in my reverse lights. My reverse lights are tinted so I wanted something brighter. When I tested the LEDS before putting them in the housings, they were so bright that they made me think of LED headlights.
It seems like there are kits out there that have "HID Like" wiring, and I'm wondering why, when other kits are just bulbs that are marketed just for fog lights or DRLs?
Why wouldn't one of these sets work in a C5 headlight?
Again, this is more of a curiosity thing than anything else. I had an HID kit in the stock housing and part of it went bad. I'm running silverstars now. Those cree LEDs that I installed in my reverse lights, without the blacked out housing looked brighter than headlights
Discuss...
Amazon.com: Boltlink LED Ultra Bright 9006 Cree Led Fog Lights Bulbs 80w 6000k White 1600lumens Dc 12v 24v All Bulbs Sizes,pack of 2: Automotive
Amazon.com: OPT7® 9006 CREE LED DRL Fog Light Bulbs - 5000K Bright White- Plug-n-Play (Pack of 2): Automotive
Discuss...
The advertised 1600 lumens from the bulbs pictured is very misleading to the point that it is almost a lie. I guarantee the mini projector bulbs forward output through the lens is easily less than 1000 lumens from the 4 led chips behind the lens. The manufacturer is adding the lumen output from every square led chip on the perimeter of the aluminum cylinder and the ones behind the lens to give a total lumen output. I've researched the topic extensively and purchased many for evaluation.
Silvania Silverstars Ultras output better, last as long (likely longer) and are manufactured to a higher standard. LED's with output of 2000+ lumens are available through VLED's or Putco and have heat sinks/fans on the backside however the construction of the LED "tower" that emits light on two sides will not work well with reflector housings and will blind oncoming traffic worse than HID bulbs. They will however work great in a projector housing with sufficient open area at the back for the heat sink/fan.
2016 Chevy Silverados come with HID's in base model and work trucks with LED's as upgrades or in LTZ models. LED's are durable, energy efficient and the technology is quickly coming of age to be cost effective.
The possible physical mounting problems due to size, etc is the first hurdle that must be overcome. I have considered LED high beams and the possible size limitations has kept me from proceeding further at this point. The need for cooling is critical and the massive heat sinks and/or cooling fans (albeit small ones) MUST to be accounted for.
Supporting Vendor
Supporting Vendor
Hmm... My headlights open & close just fine & I have LED low beams. What I like most about them is that they are much brighter than the HIDs that I had before. I'm looking around right now to see what's out there for high beams and fog lights. It really boils down to a matter of personal taste. I had HIDs and hated them. I like the LEDs better because they're instantly on and they're brighter. YMMV...
What type of led's are you using? Plus did you require any extra equipment?
Do you think or know if
Thanks,and thanks for the post.
Dave
Supporting Vendor
Much cheaper option than the sun guns (which as far as I can tell are no longer available) are the Radioflyer Bi-xenon ACA headlights.
http://shop.radioflyerinnovations.co...lights-015.htm
- Complete PNP Bolt-on installation
- HID powered Bi-xenon projector (HID low and high beam from a single HID bulb)
- LED dedicated high beam
- Normal headlight raise/lower function
- 3x lumens projected over 10x road surface:
go from this:
to this: (Bi-x low beams)
And look really slick:
Supporting Vendor
We use Cree/Epistar 16-chip LED bulbs. They average 700-800 lumens each and are meant more for signaling oncoming traffic than illumination. Most of the high beam power comes from the Bi-xenon projector.
Received 2,706 Likes
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16'-'17-‘18-'19-'20-'21-'22-
'23-'24
LED's that can replace HID's are not conventional in design and have large heatsinks or fans on the backside which may cause install issues. On VLEDS website they have high quality LED setups designed to replace HID and produce around 2700 lumens. Base 2016 Chevrolet Silverado comes standard with HID (even in base "WT" work truck)but you can upgrade to full LED headlamp and foglights...no more halogen in 1500.
