Gauging Interest: C5 Dedicated LED DRL (fog replacement)
The suitability comes from 2 factors.
1) The factory bulb is a 27w 880 series bulb rated at 540 lumens. This is hardly enough to be of use at night.
2) The LED replacement we're proposing projects 1000 lumens of 5500K light so output is not the issue. The issue is the pattern. A Driving light is designed to compete with sunlight and thus needs to create glare in order to be seen. During the day, this is useful, but at night presents a hazard to oncoming traffic (similar to using your high beams on a highway)
The C5 fog light is a good design for fog/poor weather illumination with a poor light source. Even an HID light source would not be effective as a DRL because of the pattern.
In comparison to the denali (and many other vehicles today) The fog lights are a free-form reflector style. This is an attempt by the auto industry to make a combination fog/driving light. They are cheaper to make than projectors but don't particularly function well as either. Just because a light is mounted low and far apart doesn't make it a good fog light and just because it's a reflector housing doesn't make it a good driving light.
GM's solution with the C5 (and C6) is to have the turn signal double as the daytime running light. On top of the DRL being amber (which is a sin in the minds of many) it is comparatively dim to modern LED DRLs.
So I guess my question is, how does the 885 for $5/pr compare to your 1,000 lumen LED? I think from a price point, that would be the most accurate comparison point, based on your query. Again, I know your housings no doubt have a much better focus and all around performance so that's part of the puzzle I guess too.
PS - As a quick update, I just checked Sylvanias site and they claim 1,257 lumens out of the 885 LL. So I guess this becomes more about the performance of the housings as the available output is in the same range, and definitely much better than the stock 880's.
Thanks!!
Supporting Vendor
Thanks for the reply. After doing a bit of searching here, I'm seeing everywhere that the stock fog bulb is the 37.5w 893? However, it's not listed in my owners manual and when I do internet searches I'm seeing both 880 and 893? That said, I'm also seeing that the 885 is a 50W direct replacement. Again, I'm concerned about the wiring, but I've seen scores of folks proclaiming no issues after a number of years.
Thanks!!
Thanks!!
Once the test parts get here I'll do a comparison to show the difference.
Thanks alot!
Location: Ideals are peaceful...History is violent...St.Charles, MO.
C5 of Year Winner (appearance mods) 2019
St. Jude Donor '08-'09-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22
These lights are meant to be DRLs and NOT suitable for night driving. Our planned wiring setup would automatically turn the lights off once the parking/headlights are turned on.
If you want better illumination from your fog lights, a 35w HID kit is a cheap way to get there.
http://shop.radioflyerinnovations.co...for-C5-004.htm
Obviously the best output will come from upgraded headlights. Our Bi-xenon ACA headlights will turn night into day without blinding oncoming traffic. (There MAY be a special sale price on these starting tomorrow.....Shhh )
Supporting Vendor
Test photos from today.
Test conditions:
Overcast late morning. LED was mounted at roughly the same height as the fog lights on a C5 and positioned in a cardboard box to simulate the fog light cove area. The large cardboard behind the test setup is to allow the camera to see the fog light apart from the white garage door.
10ft from light
25 ft from light
50 ft from light
100 ft from light
approx 200 ft from light
Rough guesses show a uniform beam pattern of about 50 degrees spread both horizontal and transverse. This means that even on uneven roads or turns the DRLs will remain evenly visible to other drivers.
This being said, who wants to be the first guinea pig?
I will let the first prototype go for $80 shipped if the customer agrees to provide photos of installation and finished product.
Test conditions:
10ft from light
25 ft from light
50 ft from light
100 ft from light
What is the best option for increasing the light output of the DRLs (not fogs)? I like how they put out a wide, close, flood pattern, but would be nice if they were brighter.
Supporting Vendor
http://shop.radioflyerinnovations.co...rvette-093.htm
The description of the pattern you speak of describes the fog lights. You can make them brighter, but because of their inherent design, they do not make good DRLs (See previous posts here)
Damn George, I'd be all over this if I wasn't going out of town for a couple of weeks. It would take too long to get pictures of install and final product. I'm sure I will get a set when production begins though.
Guys, you've seen the stuff George makes and you know you will not be disappointed.
The DRLs on the C5 serve double-duty as turn signals. Assuming you're referring to these, the best route is to use our White DRL harness along with the Gen 6 switchback LED bulbs:
Do you offer anything that would keep the yellow amber DRLs, but make them a lot brighter, and keep them on when the headlits are on?
Supporting Vendor
DAY:
DRL: High power
Turn signal: High/full/High/full
Night:
Parking/headlights: Low power
Turn signal: Low/High/Low/High
While we can offer a brighter bulb, we can't make it DRL brightness at night because it would interfere with the turn signal function.
#34
Night Owl for life
Received 3,247 Likes
i'll give em a shot George, lemmie know the paypal info.
#35
Supporting Vendor
Please purchase 8 custom order credits from here.
http://shop.radioflyerinnovations.co...Credit-023.htm
At checkout under special instructions type:
C5 Morimoto LED DRL Prototype.
#36
Night Owl for life
Invoice# 0000003449
Invoice Date: 02/11/2016 19:38:18
#38
Supporting Vendor
Excellent. We'll have the out to you today.
I often use the remote-start on my truck unnecessarily pumping greenhouse gases into the atmosphere. The EPA came to my home and removed my beautiful snow as a penalty for my selfish actions citing there were people more deserving. I was given a firm warning that if I did not cease my activities and buy a hybrid I would never see ice/salts on the road again.
#39
Night Owl for life
George any update to the email I sent you about the lighting options?
#40
Supporting Vendor
Yes see email (or below)
I've decided there will be a slight addendum to the wiring part of the installation that results in the DRLs functioning more like a real factory DRL than just a pair of lights that run in the daytime.
Here's a breakdown
Daytime:
DRL - On
Turn signal: DRL on the turning side shuts off allowing the turn signal to be seen easier. DRL resumes when signal is deactivated.
Night time:
DRL is off completely.
Installation of the harness involves removing the turn signal bulb and installing a modified mini-harness with power/ground that runs to the DRL. Everything is wire-loomed and should be a piece of cake.
Here's a breakdown
Daytime:
DRL - On
Night time:
