Issues with Power Windows
Old 02-08-2016, 03:24 PM
jaymarine72
1st Gear
jaymarine72's Avatar
Default Issues with Power Windows
HI, new to the forum and have recently purchased a C5 (2000) Coupe.
I got in the car over the weekend and neither one of the windows will go down? I hear a click, when I push the button but no movement.
I'm sure this has been brought up before, but I couldn't find it in any of the past threads.
I appreciate the help and advice.
Old 02-08-2016, 04:05 PM
Pounder
1/4 mile/AutoX
Support Corvetteforum!
Pounder's Avatar
Received 2,081 Likes on 1,634 Posts
Welcome !!!!! sorry no help on the window ????
Old 02-08-2016, 05:40 PM
knewblewkorvette
knewblewkorvette's Avatar
Received 2,705 Likes on 1,667 Posts
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16'-'17-‘18-'19-'20-'21-'22-
'23-'24
There are relays that go bad inside the door window module. That's what you hear clicking. The relays can be replaced or you can purchase a whole new module.
Here is what the module looks like and it is located in the door itself.
Old 02-08-2016, 06:27 PM
Studying4boards
Studying4boards's Avatar
One of my friends had the exact same problem and it fixed itself 2-3 days later when the temperature went up. He thinks that the windows were jammed because of the weather...too cold. He would also hear a click. I've never heard of it though on any car, no matter how cold it gets. His driver's side lock wouldn't work either but then started too.
Old 02-08-2016, 08:48 PM
99mike
99mike's Avatar
St. Jude Donor '17-'18
This has happened to me off and on since I bought the car in 1999. I haven't replaced anything. I think it happens due to lack of use at least in my case. I was able to get them working again by removing the door panels and the speakers. Then tap lightly on the end of the window motor while holding down the switch. It should start working again. To prevent it from happening again, I exercise them as I back out of my garage. Then when I park it in the garage, I leave them down about 1/2 inch. Haven't had any problems since. Hope this helps.
Mike
jaymarine72 (02-09-2016)
Old 02-09-2016, 05:55 AM
dadaroo
dadaroo's Avatar
I would open up one door and take a look. Could be the module or the regulator.
Replacing the relay is not too hard and they are cheap. Here is how to get into the door.
I can provide DIY on the relay replacement if you need it.
http://www.vetteessentials.com/instr...or_handle.html
Mr. Sam
To Issues with Power Windows
Quick Reply: Issues with Power Windows
