AC blows cold on driver side and hot on passenger side - HELP !
Okay so as the title reads....
AC blows cold on driver side and hot on passenger side. What the heck is going on !!!
Do I need to replace BOTH temperature valve actuators ?
Suggestions / ideas...
First you should pull codes, if the actuators are bad I believe it will show a code. Also make sure your freon level is correct. Another thing you can try is resetting the actuators by pulling the hvac fuse for 60 seconds.
Passenger side floor board. Pull the fuse box cover, read the diagram under the cover and find the hvac fuse and pull it out. Should be a 10a fuse but I don't exactly remember.
http://www.ebay.com/itm/Heat-Heater-...pASe-g&vxp=mtr
If resetting it don't work, replace both actuators unless you're young and just need some exercise. Some say they can replace the drivers side without removing the dash pad. After having mine off there is no way I'd even try that. You can buy the dorman part off of ebay much cheaper than an auto parts store. Many times 1/2 so you can get them both for what most auto places want for one. Make sure you get the right part, because the duel zone takes a different part number. They look the same, but they are not. 604-106 is the part number, just search for it on ebay.
And I looked on the CULTRAG website and it show 2 with the the same number and one different..... not sure which way to go here....
Just sharing my recent issue.
I had this happen recently but no codes.
I just got the car in December.
My first issue was the external sensor so I replaced that. Still had the same issue. I had to pull the fuse multiple times to get the logic reset. While the temp is the same on both side the car now it still seems cold unless I crank up the temp to like 78-80 on the automatic climate control. So now I am leaning towards the internal sensor.
This is what they cost at http://www.oreillyauto.com/site/c/se...eyword=604-106..
I experienced the same thing but in reverse. The passenger side was cold but driver side was not. The mechanic checked coolant and found it was slightly below normal. Added more coolant and everything went back to normal.
Go figure.
Go figure.
I gave you the part number and link to the ones you need. Don't think you will find them cheaper. 604-106 is the dorman part number you need .
If so, I'm all over this !!
And thanks again for the help !
Driver side only blows cold will not blow hot even when I change the temp. Passenger side was working and now only blows hot even when I change temp.
And yes my car has the dual zone control unit.
Here is one link, there maybe more but this one will step you through it. http://tech.corvettecentral.com/2013...-dash-removal/
It is possible to change the driver side from the footwell - the passenger side requires the dashpad to come off. Plan about 3-4 hours to pull and about the same to re-install. The actual actuators require about 30 seconds to change.
Now you need both. This happened to me in late November just as I started using the heater. In trying to re-initialize the driver side, the passenger side broke too.
