problem with a-arm???
i replaced a broken a-arm on my 97 convertible and now the tire/rim sit with a **** load of camber question is are there different length a-arms through out the years on c-5's?? or is it possible that i got a rear a-arm by mistake? there seems to be maybe as much as 2" difference in the length of the upper a-arm so it is extremely noticeable on the tilt of the rim/tire....
The correct GM part number for the left front upper control arm is 10356436, the right is 10356438 . It is the same part number for a 1998 or a 2004.
Where did you get the part - and what does your invoice say they sold you?
97 04 Corvette C5 LS1 Coupe Used OEM RH Suspension Front Upper Control A Arm
there isn't a difference between a coupe and a convertible, is there?
