Under Hood Light Connector
I have 11.44 volts at the hood lamp contacts; battery voltage is 12. 25V or so....losing voltage somewhere and the lamp will not illuminate...not enough current available.
Need another favor from someone....What does the hood lamp circuit look like? I want to find where I am losing voltage and current.
Thanks in advance.
Thanks in advance.
Appears that the last posting I did thanking those that provided the wiring diagram got lost somewhere....so THANK YOU.
I have checked operation of the lites that all share fuse 2 and found neither vanity mirror lite nor rear view mirror working. Have not checked the fuse yet, will do so tomorrow.
I assume that relay 37 is in the fuse panel at the passenger footwell....correct?
Could someone also tell me just where this I/P compartment light is at?
I spliced an electrical butterfly switch into the wiring harness of my under-hood light. That way, I can turn the light on/off when I want to. Generally I leave it off so that it doesn't drain the battery when the hood is up.
The Lizzard
The Lizzard
