ABS / Climate Control Issue
Old 04-12-2016, 02:21 AM
HutchCat
8th Gear
HutchCat's Avatar
Default ABS / Climate Control Issue
I have a 2003 Corvette Anniversary Edition with 78,000 miles. I am experiencing a problem upon starting my vehicle where the ABS light stays on and the Climate Control shuts down. After a few minutes, the ABS light goes off and the Climate Control starts working. Any suggestions of what the problem is???? PLeeeeease Help!!!
Old 04-12-2016, 05:55 AM
dadaroo
dadaroo's Avatar
Any DIC codes? What does shut down mean?
Mr. Sam
Old 04-13-2016, 02:46 AM
HutchCat
8th Gear
HutchCat's Avatar
Default Climate Control / ABS
Mr. Sam
Ive checked the codes and I am currently in the processi of getting my EBCM repaired by ABSFIXER. However, my climate control completely shuts down while the ABS light is on. It only does it for about 3 minutes after vehicle startup. Shut down means climate control completely shuts down. No A/C, No Heater. Temperature light even goes out. As if it were disconnected. Now that my EBCM is taken off for repairs, my ABS light continually illuminates with my ignition on. The climate control will still shut down for about 2-3 minutes before coming on. I read once on this Forum that another C-5 owner was having the exact same problem. Did not get the solution to his problem.
Old 04-13-2016, 05:40 AM
dadaroo
dadaroo's Avatar
The ABS light is going to be on without the EBCM installed.
Mr. Sam
Old 06-02-2016, 01:16 PM
HutchCat
8th Gear
HutchCat's Avatar
Well I finally installed my new EBCM and still had issues. I conducted some research and determined that the problem most likely was a faulty Body Control Module. Ordered one and took it to the dealer to have it installed and programmed. Turned out that the actual problem was my ignition switch which was faulty. $685.00 later, I'm back on the road. Thanks for all of the replies and suggestions. By the way, Im sitting on a remanufactured Delco Body Control Module fore a 2003 C5 if anyone needs one.
To ABS / Climate Control Issue
Quick Reply: ABS / Climate Control Issue
