C5 advise
C5 advise
Hey guys (and gals),
Looking to move from a C4 to a C5. I have an eye on a 2001 with 52K and it looks to be in very good to excellent condition. Price is fair based on what I see similar one being advertised for and what they are being listed on this forum for.
Anything in particular that I need to be aware of with the 2001 model year? Like most cars I know newer years come with upgrades and improvements. But, is there anything I need to look out for or be aware of that is common for 2001?
Most reviews are pretty flattering for the C5 so I know I'm making a good move from my current C4.
Thanking all those who respond in advance!
Received 19,233 Likes
'20-'21-'22-'23-'24
Read these threads and go from there. Lots of good info in them.
https://www.corvetteforum.com/forums...ion-files.html
https://www.corvetteforum.com/forums...must-read.html
1/4 mile/AutoX
If you liked a C 4 you will LOVE the C 5
chasboy (05-01-2016)
C5 improvements made on the 2001 and up models…
2001
return to 28# injectors for all models.
Second Generation Active Handling
Nassau Blue discontinued
Alternator 'clutch' pulley added on A4 cars
New soundproofing + foam in all cars
Smaller keyfob
electrochromic dimming rearview and driver's mirrors
lighter AGM battery
Thickness + Material in vert change
Chrome exhaust tips for coupe + vert
85MM MAF with integral temp sensor (versus 74mm with separate plug for IAT)
LS1 cam profile changed to: .500/0.500, 198/208 on 115.5LSA (From: 0.472/0.479, 202/210 on 117)
All Corvettes now have the LS6 intake manifold
All Corvettes now have the LS6 engine block (windage passages in block), which includes a beefier oil pump.
LS1 changes result in new output of 350 HP @ 5200 RPM and 375 Ft Lbs of torque @ 4400 RPM (MN6)
Hardtop/FRC discontinued
Pup cats added to all models
Stronger synchros in all transmissions
Exhaust manifolds revised (5hp regained) - thin wall cast replacing SS manifolds
metal valvestem caps (late year)
Torque Tube changed from metal-matrix composite to aluminum alloy 6061, increased in dia from 55 to 63 mm.
Driveshaft couplings have also been upgraded on manual-equipped models for additional strength and durability
Introduction of the Z06, which has as differences:
hardtop body style
rear brake ducting
screened inlets on front fascia, without foglights
F1 supercar tires 265-17 front, 295-18 rear, on 17x9.5 and 18x10.5 (one inch wider, respectively
new LS6 top-end with new style head design (10.5:1 compression, 64cc chamber), LS6 cam (0.525/0.525, 204/211 on 116) - 385hp
M12 transmission with shorter gearing (1-2-3 analagous to MN6 with 3.90 rear diff
Titanium exhaust system
lightweight windshield
New, stronger clutch with redesigned master + slave cylinder
Stronger rear differential (shotpeened ring gear)
Red brake calipers (otherwise identical)
Trans overtemp warning light on DIC
6500 redline gauges with special checkering + Z06 font
redesigned PCV system to help combat oil burning
Red LS6 Fuel Rail Covers (FRC's)
FE4 Z06 suspension - uprated springs, bars (30mm/23.6mm), shocks (note front spring and rear bar same as Z51)
2001
Smaller keyfob
lighter AGM battery
hardtop body style
rear brake ducting
You will be very happy with the change up to a C5. Light years ahead of earlier gens (I've had 'em!), just a wonderful, hard to beat, driving experience for the performance enthusiast, especially considering the modest sum required get into a high quality example. C6 and C7 drivers will throw rocks, but I think C5's are the bomb!! Best wishes!
2001 is the oldest model to consider since it was essentially a mid-cycle refresh with lots of upgrades. Make sure you drive one before buying, it's much different than the C4, and not everybody loves it better.
