Question about front plate cover
I was going to paint a front clear acrylic cover to match the car and run it on the front. When I removed the cover, this is what I see. I'm sure I'm missing something. The only thing behind the cover is a foam gasket. Isn't there supposed to be a blank plate? I don't see any way to make it work like this.
Thanks in advance,
Shakey
Thanks in advance,
Shakey
Somebody has modified the car. When the front plate beauty cover is removed there should be a portion of the fascia that has a mount setup to put a plate. This area is frequently cut up to allow more air to enter the front fascia.
EDIT: Here you go. This is what it's supposed to look like when you remove the front license plate cover.
Shakeydeal (05-27-2016)
So I guess I am jst SOL?
Shakey
Received 19,275 Likes
'20-'21-'22-'23-'24
If you go with option 2 above, I would use a patch of Velcro instead of double sided tape. You could have one heck of a time getting the plate off to put on new registration decals if you use double sided tape, depending on how much tape you use.
whats on the other side of that foam? Ive seen cold air intakes pull from there as well as aftermarket light kits.
Won't help you but, I love this look in yellow...
