Cruise controll
Cruise controll
On my new to me C5 the cruise control doesn't work. To check the easiest thing first, which and where is the CC fuse ? Thanks, Bob
Received 19,286 Likes
'20-'21-'22-'23-'24
On my '03, I believe it is fuse number 20 in the passenger foot well. Not sure what year your car is - but you can check the listing of fuses in the owner's manual for your car.
I found this interesting link about pulling the brake pedal upwards...
http://www.corvetteactioncenter.com/...trol-quit.html
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
It can be a LOT of things but, pulling and posting DTCs is an easy way to help pin point the issue.
Usually its the brake and or clutch switch out of proper adjustment. If the switch isn't compressed, CC will not function
Bill
Bill
mine too was acting up, put my foot under the brake pedal and pulled it up and the cruise worked. pulled the panel under the dash (felt like it was the hottest day of the year!)adjusted the right brake switch 1 click and moved the metal retainer in also. the cruise works fine now.
Google info about adjusting the brake switch. There are two of them under the brake pedal. Push them in until you hear them click. Hardest part is getting to them...........
1/4 mile/AutoX
