Need brighter headlights
I put Corvettemods projectors with a 55w 5000k hid (ACA copies) they were about $300 and the ballasts came with lifetime warranty. HUGE improvement over stock. Sure Radioflyer makes better ones I'm sure but I'm 100% satisfied with mine...
Received 2,706 Likes
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16'-'17-‘18-'19-'20-'21-'22-
'23-'24
I had the corvettemods kit and the radioflyer kit. They were both upgrades but the radioflyer kit is really a much kit. The pattern and lighting was just as big upgrade over the corvettemods as the corvettemods was over stock.
Supporting Vendor
My latest pics from a customer
Low beam. This will NOT glare in the eyes of oncoming traffic.
High beam: When you need it, you have a wall of light. Tackle the darkest country roads with confidence.
But I was commenting directly on the original poster's question about an "HID or LED bulb" that would just swap in. You can't just swap in and HID bulb or LED bulb. You have to buy an HID kit, and I've yet to see a working LED bulb in the headlight of a C5.
I do not necessarily agree with you.
Unsure exactly what the OP is planning but there is a clear film that is legal to put on the windshield whose purpose is to reduce the ultraviolet light from the sun in an attempt to help keep inside temps from getting as hot in the summer sun. I know several that have this coating and claim a significant improvement.
If that is what the OP is planning to do there should be no legality issue.
Legal is such a prospective based term. I tend to lean on the interpretation that it is only illegal if you get caught (in the case of uv film on windshield) but who am I to say.
#33
I'm considering of putting the HIR 9005 high beam bulb on the low beam spot. Just curious, do they emit white light or is it still yellow?
Which one is better? Silverstar Ultra, Phillips Crystal vision or the HIR's? I'm trying to get that white bright light..
