trans oil for automatic
I was reading the post on smoother shifts for the manual. Is there a better trans oil for an automatic? Just wondering. You folks answer so many of my novice questions. Thanks in advance.
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The AMSOIL ATF "TORQUE DRIVE" is an excellent ATF. Contact a forum AMSOIL Guy for details or go to NAPA. My local NAPA sells it.
BC
BC
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Check out this post.. Same info that you need!
https://www.corvetteforum.com/forums...th-shifts.html
I would not recommend flushing a transmission. If the fluid in it is very old or burnt, you can do a couple of fill and drains to get it out. I myself use Redline's high temp atf but I have also had great results with Valvoline max life.
Pops you know they can change the shifts in your A4 with a tune... hard shifts, firm shifts, soft shifts, teeth jarring shifts... they can do a LOT to change your A4 performance... Chuck CoW is in OKC every year... had him do a street tune for our MN6 car and it is AWESOME.... might give him a call and see when he's back in our area...
