TP's Modding/Repair/Maintenance Thread
Old 08-10-2016, 12:35 PM
tommypenguin
tommypenguin's Avatar
Default TP's Modding/Repair/Maintenance Thread
This thread is dedicated to my experiences with my 01 Corvette it is a manual. This car is my first Corvette. Hopefully there will be little posting regarding repairs and more so on the maintenance and modding. I have started one of these with my last two cars I've purchased and finally have decided to do this with my Corvette. For reference below are the two threads I created when modifying my subaru legacy and honda accord prior to getting the Corvette if you're bored and want some bathroom reading below might provide some entertainment.
Legacy GT - http://legacygt.com/forums/showthrea...ad-112966.html
Accord - http://www.driveaccord.net/forums/51...ng-thread.html
Here is a link to my YouTube channel, am now documenting my mods there.
https://www.youtube.com/channel/UCZc...flQsXQPbABd__A
Been finding it difficult to remember everything I've done with my Corvette, posting it all here will help me keep track. Breaking this into 2 separate posts. One showing where the car was when I got it, and one showing where it is now.
I purchased this car sight unseen from a wonderful member on the forum, JMBBluevette (Joaquin). It arrived with many mods already on it, I wanted a heavily modded Corvette and knew if I didn't buy one built I likely would not have the funds to do so otherwise.
When I received the Corvette it had the following...
• 243 heads with PSI beehive springs
• Thunder Racing cam (220/220 .561/.561 114 LSA)
• FAST 92 intake manifold
• LS2 throttle body
• 60 lbs. Injectors
• A&A SC with 3.6 pulley
• LPE fuel pump and boost a pump
• 190 degree DYI thermostat
• PCV oil catch can
• FLP header with high flow cats and x-pipe
• GHL magnum catback
• East Coast Supercharging (ECS) rear end with 3.90 gears
• Fidanza 6.5 dual clutch
• RSD C6 Z06 snap shifter.
• DBA cross-drilled/slotted rotors/Hawk HPS pads
• Bilstein sport shocks
• C6 Z51 sway bars.
• GM European clear tail lights
• Race mesh fog light grilles
• Caravaggio rear spoiler
• Shift bypass, column lock bypass, embroidered
• Hood liner, SS exhaust plate, and radar detector
• Cooling Mist Methanol Kit
• CCW SP20A Wheels 20 x 11 (Toyo T1R 305 30 20 Rear) 19 x 10 (Toyo T1R 275 30 19 Front)
A video of how it looked when I got it.
The following 2 users liked this post by tommypenguin:
1Willy1 (09-29-2016), blackmachdown (12-03-2016)
tommypenguin
Since picking up the Corvette I've been busy. I have done the following...
Mods:
• Wrapped Halo and Rear Fascia in Gloss Black Vinyl
• 5% Tint
• C5 Z06 Brake Ducts
• RF V3 Headlights with Custom XBALed Halos
• RF Tail Lights
• RF Clear Corners and Switchback Leds
• Diamond Cut Read Signal Markers and Reverse Light Housing
• Swapped out Oak Interior For Black
• C5 Z06 Red/Black Seats
• Pioneer DEH-80PRS Deck, MBQuart PVM216 6.5”, Polk DB351 Rears, Alpine SPR-10TW Tweeters, Rockford Fosgate R600X5 Amp, P1S2 10” sub, VetteNuts Sound Deadening Kit
• C6 Z06 Shifter ****
• Lowered stock bolts as far as I could
• C6 Z06 BBK
• Forgestar Wheels 19 x 11 (305 35 19 NT05R Rear) Forgestar raised center caps to clear axle nut
• 19 x 9 (255 35 19 Invo Front) 3mm Akata Spacer in front to clear BBK Caliper
• 3 Angle Valve Job on Heads
• 220R Comp Cam
• FP, AFR, Boost Gauges
• Anti-Venom Mod
• Tick Clutch Remote Bleeder
• C5 Z06 FRC
• Curb Alert Parking Sensor
• Dual Cup Holder
• Fire Extinguisher and Ebay Mount
• Tint Front and Rear Signal lenses
• Painted Front Fog Light Grills
• LS1 Supercharged Badges
Maintenance:
• Amsoil Torque Drive Tranmission Fluid
• Joe Gibbs LS30 oil changes
• Coolant Change
• DOT4 Brake Fluid Change
• Clutch Fluid Change
• PS Fluid Change
• Starter
• Tensioner Pulley Replaced
• C7R Timing Chain
• Timing Chain Dampener
• Slave Cylinder
• Pilot Bearing
• Water Pump
• OPS
• Belts
• Plugs
Repairs:
• Replaced Engine Block (Lessons Learned https://www.corvetteforum.com/forums...s-learned.html)
• Replaced Lifters with LS7
• Piston Rings (Sealed Performance)
• Crank/Rod Bearings (Clevite)
• Replaced Relays on both door control modules
• Repaired Dim Climate Control Screen
• Replaced squeaky radiator fan motor
• Replaced Oil Pump with Melling
Pics of the car as it sits today:
tdf01cycling (11-12-2018)
Old 08-23-2016, 11:08 AM
tommypenguin
I didn't know how old my battery was and figured I should replace it as preventative maintenance. I might call Guinness Book of World Records while I'm at it, my optima red top lasted 10 and a 1/2 years and was still going strong.
Old 08-30-2016, 11:36 AM
tommypenguin
Did an oil change yesterday and switched back to synthetic for the first time since rebuilding my motor. Cut the filter open and inspected it along with the drain plug, everything looks great. Put Joe Gibbs LS30 oil back in. Will go back to 2000 mile oil changes now that I'm through the break in period.
Next up a mod, going to install the tick master cylinder and flush my clutch fluid with my remote bleeder. Running Castrol DOT 4 fluid.
Going to have a repair to address in the somewhat near future, for whatever reason the people GM had to soldering on circuit boards did a terrible job. I had no soldering skills prior to buying this car, now I can solder about anything. If there is one tool that is damn near mandatory to own for a C5 to save yourself of costly repairs it's a good soldering iron.
I have had to solder in new relays for both door control modules when the power locks went out. Have had to resolder the climate control display and now I got the dreaded TCS 1214 code, which means I will have to pull the EBTCM module, open it up and resolder those joints on that circuit board. I cleared the 1214 code and it hasn't come back but from what I've read I can expect it to keep coming up sporadically until I decide to fix it.
Old 09-06-2016, 10:26 AM
tommypenguin
Installed the tick master cylinder yesterday. Took 4 hours and a sore back to do it. Was one of my least enjoyable installs on the corvette given you have to work upside down under your dash hanging out the door. I bled my clutch fluid via remote bleeder. Was shocked to see that only 2000 miles after replacing my slave my clutch fluid was pretty pretty black. Going forward I'm going to start doing the ranger method every 1000 miles and a full flush every oil change.
Still have to adjust the master will do this over the next week. Next up going to change out the diff fluid with amsoil and wire up the harness for DMH low profile electric cutouts.
Old 09-06-2016, 11:56 AM
Esser
Esser's Avatar
I would advise going for QTP cutouts over the DMH. I've had so many issues with DMH, and never had a single problem with my QTP's.
Old 09-06-2016, 12:41 PM
tommypenguin
Thanks for your post. I was going with DMH over QTP because of the 4 year warranty and then had read of many members trying to get their cutouts warrantied unable to get a hold of DMH in addition to quality issues with them. Going to go with QTP instead.
Old 09-06-2016, 12:44 PM
Pounder
1/4 mile/AutoX
Support Corvetteforum!
Pounder's Avatar
Received 2,082 Likes on 1,635 Posts
You have been busy, very nice !!!!!!!
Old 09-06-2016, 03:20 PM
Brit dex
Brit dex's Avatar
Nice car.... that's some list!!!
Old 09-06-2016, 03:30 PM
friou
friou's Avatar
Well, I can tell you haven't been bored! Very nice vette, looks wicked! Best wishes!
Old 09-06-2016, 06:37 PM
tommypenguin
Thanks guys the car is just a little different than when I picked it up Have done all of this stuff over the last 2 years and 2 months. Also wrapped up grad school and had a baby during that time, rarely a dull moment around here.
Before buying this car would consider myself a mild car DIYer, now I've crossed over into the more hard core territory. Done all the work myself on jack stands except for machining the block/heads/crank and tuning the car.
For the most part I believe there are two types of car enthusiasts, riders and builders. Wouldn't surprise me if I have more hours into working on it than driving it, love doing both. But probably get just a little more joy out of building than I do from driving the car.
Will chime back in when I get on the next projects.
Old 09-10-2016, 01:44 PM
derz_vette
derz_vette's Avatar
Car looks great... looks like you have been putting some money and time for sure
I've realized I probably could have just bought an almost new C7 for the stuff I've done to my car now. :| Would have been more reliable as well.
OH WELL
Old 09-10-2016, 03:19 PM
S.C. vette
S.C. vette's Avatar
x2
Old 09-13-2016, 12:12 PM
tommypenguin
Changed the diff fluid and went with Amsoil fluid and slip lock.
Pulled the X pipe, tunnel plate, and radio/center console. Wired up the cutout switch and am doing a little ghetto mount for it much like my afr gauge where I cut up an old dvd case as the mount.
For the switch I pulled the cigarette lighter out next to the ash tray and am using a big washer I painted black to mount in that location. Need to run the wire to the transmission area and put everything back together.
A buddy of mine has welded in his cutouts previously and offered to do so for my car. Going to swing by sunday to do it and get a tutorial on welding. That is a skill I would love to learn but have no experience with. Will get pics and video posted after I'm done.
Old 09-19-2016, 10:39 AM
tommypenguin
Did the dip stick mod of drilling an extra hole to more easily be able to check the level.
Also got the cutouts welded in yesterday, my friend did a great job was the first time since I've owned the car it has been on a lift. Man do I wish I had one in my garage and a welder, and a lot more air tool attachments Will try and get some video soon. Pics from the job.
Old 09-25-2016, 04:12 PM
tommypenguin
Couple sound bites of the cutouts...
https://www.youtube.com/watch?v=2cZqJmAEn64
https://www.youtube.com/watch?v=NLLmAgghEuY
Old 09-26-2016, 06:45 PM
tommypenguin
Installed a metal shifter ring for my shift boot from an ebay seller to replace my plastic one. Always had a gap between my shifter boot and trim because of it. Fixed. Also picked up HPTuners Pro so I can make a copy of my tuned map in addition to start learning how to tweak it.
To TP's Modding/Repair/Maintenance Thread
Old 09-29-2016, 09:16 PM
tommypenguin
Got HPTuners Pro this week and was excited to start logging with it in addition to making some tweaks to my map when I got my first repair(s) to do since creating this thread. Got the dreaded TCS 1214 EBCTM issue it has popped up a few times over the summer but went away after restarting the car. Tried clearing the code and starting the car several times and going for a drive in addition to resetting the battery and the code will not go away.
Jacked the car up so I could more easily access the EBCTM from underneath to pull it but discovered another issue to repair. My methanol is leaking right at the sprayer at the quick connect fitting. I believe the methanol system is 4 or 5 years old I did not originally install it. I ordered a new checkvalve, spray fitting and quick connect.
When I install the checkvalve I will make the methanol spray at idle to flush the line of air, then set it back to only spray during boost. Also had to pull the powersteering cooler to get more access to the EBCTM, will have to flush PS fluid. Also need to research how to log my afr with my aem wideband via hptuners to ensure the methanol system is working correctly after fiddling with it when hitting boost. I suspect my car will be out the game for a week or two while I sort these issues out. Knew I jinxed myself when I told a friend of mine I was finally out of projects to work on for the car till next year. Famous last words.
Old 09-29-2016, 10:05 PM
1Willy1
1Willy1's Avatar
all the work you've done to the car is impressive
I briefly went through that other thread you posted and I still cant see why you ended up rebuilding the engine, did something go wrong or was it just to make it more bulletproof?
Old 10-01-2016, 04:40 PM
tommypenguin
Thanks. Reason I rebuilt the motor is that one of the two previous owners had a shop install 243 heads on my car. When the shop did that install, they must not have cleaned out the head bolt holes and when they torqued down the head bolts they cracked the block along a head stud.
While tearing down to troubleshoot the initial issue I discovered the crack on the block, and because the block is aluminum and my car is making significantly more power than stock I couldn't find a shop willing to stand behind welding it. There was no way I was going to roll the dice and reuse my block knowing it had that crack in it. Figured I might as well replace rings and bearings as well. Here's a couple pics of the crack in the block...
1Willy1 (10-02-2016)
Quick Reply: TP's Modding/Repair/Maintenance Thread
