[Z06] best mild cam for sound & longevity
Old 10-01-2016, 12:53 PM
SLO VETTE
SLO VETTE's Avatar
Default best mild cam for sound & longevity
Looking for a little bit of lope on my almost-all stock '04 Z06. It's got a mild tune and Vararam on it now. Car has about 40k miles.
Just looking just for great sound & lope fun (but not too much), don't care about power adding, as I'm more than happy with the car now. Most concerned about longevity and no emission, electronics or other related issues.
Can fellow CF pals recommend a cam spec that would meet this general criteria? What else would I need to be concerned about getting done in conjunction with cam modification?
Am meeting with a reputable tuning shop to discuss this also, but I'd like to get a little educated first. Thanks for any tips.
Old 10-01-2016, 04:11 PM
wrkdWS6
wrkdWS6's Avatar
Since longevity is a concern I would recommend a cam that is on milder lobes. Some of the aggressive cam lobes being used these days will wear out valve springs every say 20k miles so that's something to be aware of. If you want some lope then you will want something with a little overlap to it. However, too much overlap will negatively affect driveability and emissions so that's another thing to keep in mind. Since you have the stock manifolds and h-pipe I would personally opt for something that has an appropriate intake and exhaust duration split that takes the exhaust restriction into account. I would speak with some known LS cam gurus to see what they can set you up with to achieve your goals. Some names that come to mind would be Ed Curtis at FTI, Martin Smallwood, Tony Mamo, Brian Tooley, Geoff at EPS, Pat G.
In addition to the cam you will also need/I would suggest considering:
-Valve springs (I would suggest a kit that includes retainers, locks, seals. Springs must be appropriate for selected camshaft)
-Pushrods (Must be appropriate length)
-Timing chain upgrade such as the LS2 chain (Not mandatory but a good idea. You will probably also need a dampener)
-Trunion upgrade kit for your stock rockers (Not mandatory but a good idea)
-UD pulley + belts (Not mandatory but something to consider while you are there)
-Dyno tune
-Gaskets
-Fluids
-LT Headers w/ X-Pipe (If you want to optimize the sound and power you get from the cam swap)
Hopefully I am not missing anything but that should give you a general idea.
Old 10-01-2016, 04:52 PM
SLO VETTE
SLO VETTE's Avatar
Thanks a bunch.
Heading to tuners now, so your post is timely.
Old 10-01-2016, 08:39 PM
winters97gt
winters97gt's Avatar
-Dyno tune
-Gaskets
-Fluids
Old 10-01-2016, 09:47 PM
~Josh
Banned Scam/Spammer
~Josh's Avatar
Received 1,319 Likes on 788 Posts
Sound rule of thumb almost regardless of duration and lift, the Lobe Seperation Angle has the most effect on audible lope. Duration isn't recommended much past 230 on stock cubes. Makes the low end soggier and has bucking and surge at low rpm around parking lots. Shorter duration is snappier.
114LSA = nice burble at idle and has a nice yowl through the rpm range.
113LSA = sounds like a gallop, not quite a solid chop
112LSA = choppy and old school, advantage of lower LSA is boosted midrange.
My cam? I forgot the exact specs but its a Comp 224/228 .588/.588 114LSA.
With headers it's got a mellow personality and sounds like its modified but to the layman they might think its factory. 114 works well with a blower too.
Old 10-02-2016, 12:06 AM
wrkdWS6
wrkdWS6's Avatar
Be careful with LSA absolutes. I too use to think the LSA of a cam was the main driver of idle quality but it's actually not. The biggest driver of idle quality or sound is overlap. LSA is just part of the equation in determining overlap. A 220/220 110LSA cam will have a smoother idle than a 230/234 114LSA cam because the 230/234 cam has more overlap despite it having a wider LSA.
I like this stuff so for anyone interested...(Intake duration + Exhaust duration / 2) - (LSA x 2) = Amount of overlap. The greater this number, the more chop or rougher the idle will be.
The following 2 users liked this post by wrkdWS6:
Glendows (10-02-2016), Whatsa347 (10-05-2016)
Old 10-02-2016, 02:08 PM
Mistrezz 06
Support Corvetteforum!
Mistrezz 06's Avatar
Slo Vette post what the tuner recommend you if you don't mine, I'll been thinking some mild setup for mine also. Thanks and good luck !!!
Old 10-04-2016, 09:55 AM
SLO VETTE
SLO VETTE's Avatar
Will do.
Old 10-05-2016, 01:27 AM
winters97gt
I can't stress enough to you to go to guys like Arun, Pat G, Brian Tooley, etc.
I went against these big shops and speced my own cam in my C6. Car trapped 149+ on a Novi 1500 in full street trim with no drag setup, just heavier Fbody wheels out back with 17 inch drag radials and a cage. No trailer, and hurt F series blower car feelings. It was on a 118 LSA and 12 pounds of boost.
Old 10-05-2016, 05:43 PM
turboffr
turboffr's Avatar
St. Jude Donor '10
Originally Posted by winters97gt
I can't stress enough to you to go to guys like Arun, Pat G, Brian Tooley, etc. I went against these big shops and speced my own cam in my C6. Car trapped 149+ on a Novi 1500 in full street trim with no drag setup, just heavier Fbody wheels out back with 17 inch drag radials and a cage. No trailer, and hurt F series blower car feelings. It was on a 118 LSA and 12 pounds of boost.
I agree 100%. Pat G gets my vote because I've dealt with him 3x now and always had great results, but I've also heard nothing but good things for the others listed.
Old 10-05-2016, 06:43 PM
Whatsa347
Whatsa347's Avatar
Your tuner will make and break your drivability. LSA has absolutely nothing to do with sound please for the love of god do not go by that, LSA is a determination of desired valve events not how you want your cam to sound. Talk to Ed Curtis if you want the most detailed cam sheet, who knows, based on your desires your camshaft might be ground on a 110 LSA, but the man is a walking messiah for valve train information, same with Martin Smallwood and Brian Tooley, all can set you up with perfectly streetable (again, this will ALL depend on your tuners ability) camshaft setup.
Old 10-05-2016, 08:12 PM
SLO VETTE
SLO VETTE's Avatar
Turns out I'm not going with a cam. Gonna do some other tinkering. All the really smart advice here was similarly echoed by the tuner. He could've easily sold me on a lot more stuff (and he's fully capable of doing the install) and made 2-3x what it's gonna cost me, but he didn't. Instead, talked me out of a few things I thought I wanted, said go smartly step by step and do things right and over time that matches my driving preferences, budget and longevity concerns.
Old 10-05-2016, 08:26 PM
turboffr
turboffr's Avatar
St. Jude Donor '10
I hope by other "tinkering" you mean this......
https://www.corvetteforum.com/forums...-one-only.html
Old 10-06-2016, 07:24 AM
SLO VETTE
SLO VETTE's Avatar
Hah! Nope. But....am laying the foundation for something like that down the line.
Andy's a 1st class operation, I drove my Z almost literally from the dealer to his shop (a several hundred mile trip) for its 1st oil change, tuning & a dyno run (was living in CA at the time, am now on east coat). He worked on my prior C5 also.
Old 10-06-2016, 11:43 AM
Shakeydeal
Shakeydeal's Avatar
From your handle, I presume you lived in San Luis Obispo?
Shakey
Old 10-06-2016, 11:55 AM
SLO VETTE
SLO VETTE's Avatar
Somethin' like that.
Shakey
Old 10-06-2016, 01:51 PM
Shakeydeal
Shakeydeal's Avatar
I used to live in Grover City and Shell Beach many moons ago. I worked at Diablo Canyon PP. I spent many nights at The Graduate in SLO...........
Shakey
To best mild cam for sound & longevity
Old 10-06-2016, 02:45 PM
SLO VETTE
SLO VETTE's Avatar
end of an era at diablo. pretty dumb thing to shut down, but the political winds there are, well.....full of some funny smelling smoke.
Shakey
Old 10-06-2016, 03:14 PM
Shakeydeal
Shakeydeal's Avatar
Yes I remember having to deal with the Sierra Club and Mothers for Peace on a regular basis. Batshit crazy.........
Shakey
Old 10-06-2016, 04:57 PM
SLO VETTE
SLO VETTE's Avatar
gov. brown's direktorate will soon mandate that 15% of the state's power generation is to come from pixie dust.
Shakey
Quick Reply: [Z06] best mild cam for sound & longevity
