Tire Sensor Change Help
https://www.corvetteforum.com/forums...lve-stems.html
Post #9 by BC shows the 2001-2004 sensor with the clock face date code in the lower right.
Received 2,681 Likes
2018 C5 of Year Finalist
All 4 sensors are the same. ACDELCO PN 25773946.
If possible check the manufacture date on the sensors BEFORE you purchase. OEM sensors have a clock face with an arrow pointing to the manufacture month and on either side of the arrow is a digit to indicate the 2 digits of manufacture year. You do not want TPMS that were manufactured 5 years ago........
Sensor 1: April 2010
Sensor 2: April 2010
Sensor 3: March 2012
Sensor 4: June 2012
So based on this, they sold me two sensors that are already over 6 years old. I'm not sure if these suppliers rotate stock, however based on these dates, should I return the sensors? If so, what is the best way to order sensors to confirm that the manufacture date is a recent as possible?
I would send all of them back.
See if you can can find the Schraeder aftermarket sensors. They make the GM sensor. If your buying from a company that specializes in tire sensors, the stock probably turns over faster. I've read where others have had the same problem when buying the GM sensors.
MSG C5 (12-12-2016)
TPMSDirect sells the Schraeder 20117 for a 2004 for about $70. Give them a call and ask if they have fresh stock. I've never purchased from them so I can't speak on that.
Tirerack has what looks to be the same sensor for $42 P/N 9117. They probably have good stock turnover.
Rock Auto has Schrader's for $30 on a "closeout". They have closeouts fairly often though. I got mine as a closeout a couple of years ago.
I think they go through a lot of sensors so they should be fairly current dates. When I got mine they were all about a year old.
Good luck.
Good luck.
I have a RR Tire Pressure Low sign on my 2004. I have put the pressure up to 40lbs and the display stays on.
Am I correct to assume I need a new sensor.If I do I keep seeing reference to using a magnet to program the sensor. How do I do this?
Thanks,
Stephen
Thanks,
Stephen
Update - I sent the original 4 sensors I received back to Amazon for a refund and I ordered 4 new sensors through Forum Vendor GM Partshouse. I sent them an email confirming that I need "fresh" sensors and they sent me four new sensors. They arrived today and they all appear to have been manufactured in 2015 so good news. Also note that the sensors manufactured after 2012 now show the two digit year date embossed on the little clock, so all mine list "15". The arrow then points to the month manufactured since the clock displays 1-12.
