Dysfunctional tools; what's new?
Purchased a Fuel Line Disconnect Tool for my '98. Walked out into the garage and tested the tool to see if I could actually use it, since that's the biggest problem I ever have with working on my car. Turns out (wow what a surprise) that the tool bumps on the bracket before fitting into the quick-release socket. I've read multiple threads on this and apparently everyone has issues releasing the tabs, and not actually getting the tool in? What's the problem here?
Any suggestions for a proper tool?
Received 1,261 Likes
is your tool metal or plastic?... the plastic ones are junk, I have a set from matco that I use and never had an issue
1/4 mile/AutoX
thanks for the fast reply!
yeah mine are the same type... are you trying to disconnect the lines at the rail or the fuel filter?... if you open the tool up and slide it around the line then insert the end of the tool into the fitting and push it should pop loose
I have a set of the plastic tools, in various sizes, and they work fine. The trick is how you use the tools.
Pull back on the fuel line, to give yourself some working room. Set the tool in place, on the metal line, as far from the fuel line as you can. Then push the fuel line "forward", like you were installing the fuel line. Next, press the tool into the fuel line, and this action will push back the retaining "fingers" into their open position, allowing you slide the fuel line, with the tool still in place, off the metal line.
I'll admit that the plastic ones are kinda junky and I struggled when swapping the intake manifold. But after several attempts, I decided to use the next size down and the fuel line almost fell off by itself.
I made my own fuel line disconnect out of the tip of a funnel in a pinch. Worked so well that I still have it for when I need it next!
It's much sturdier than the plastic disconnect tools, but I didn't want to run to the store to buy a set of metal ones since I was already under the car.
