Borla Stingers question/issue?
Just had them installed on my C5 z06 along with an X pipe. At a specific RPM range(not sure what range, need to look)), I get a "buzzing" noise inside the cabin, almost as if the exhaust is vibrating/hitting somewhere. It's not drone. Could this be normal interior resonance?
Supporting Vendor
After a closer look, it happens between 2-3K RPM's when hitting the gas(in gear). Definitely sounds like it's coming from the passenger side. I think something needs to be adjusted.
St. Jude Donor '13, '15
Check for alignment of the xpipe near the gas tank metal heat shields. My XS Power xpipe was a bit closer to the drivers side than the passenger side and it would put off a slight buzzing vibration at a certain RPM as well. I had to do some fine tuning of the install and push the heat shield out of the way a bit.
ArmchairArchitect (07-06-2017)
Sub'd for solution.
I have Borla S-Type II mufflers on my '01 coupe and have the same problem. Around 2.5k RPM when the car is warmed up there is a buzzing coming from the drivers side that is definitely resonance related. I have not been able to eliminate it or pin point it. At first I thought it was the heat shields, and it still may be, but I tried bending them and contorting them such they they held a different shape with no luck.
Sub'd for solution.
Sub'd for solution.
Buzzing
Apologies for waking an old thread, but was there any conclusion to this? I'm having exactly the same issue, C5 coupe with Borla S-Type II, loud resonating / buzzing noise between 2.5k and 3k rpm. Really annoying, and quote vocal outside the car too. It sounds metallic, so I'm wondering whether it's the Borla muffler itself. I also checked heat shields and there's plenty of clearance there.
I'm going to mount a camera with speaker near the exhaust tips to see whether it's more 'back there'.
/Andy
/Andy
Resolved
/Andy
/Andy
Just wanted to give a shout-out to the awesome customer care that Borla demonstrate. Very good company, and great product.
