to insulate...or not to insulate...the hood
the hood insulation on my 2000 vert is falling apart.
I am going to remove it during the next warm spell.
Question is....why did they put it there?
Is the function to protect the paint on the top of the hood??
Or to lower the engine bay noise??
Opinions welcome
I am OK with spending the money to replace it...I just need to know why.
Opinions welcome
There is a lot of heat produced in the engine bay. Almost all cars come with similar insulation. I live in the south where heat is an issue. In the event of a fire the insulation is designed to fall and help to retard the flames. I'm not sure about how it helps with noise but the cabin in mine is noisy enough.
Unless mine was an all out racer, I would rather have it than not.
I'm not sure how much a new one is but you may be able to refurbish yours with some spray contact adhesive.
DaDuck (12-09-2016)
Received 19,293 Likes
'20-'21-'22-'23-'24
DaDuck (12-09-2016)
Received 1,261 Likes
I have had mine off for a couple of years, no issues here either and it looks a lot better without it in my opinion... I think it's mainly there to reduce noise
DaDuck (12-09-2016)
Received 3,866 Likes
2015 C5 of the Year Winner
If you decide to remove the liner, you might run in into something I found when I changed mine out. The underside of the hood wasn't painted all that well. It actually showed more silver then purple. So I have it painted before I put the new liner on just in case I ever decide to leave it off. Look at yours before you decide to leave it off.
DaDuck (12-09-2016)
2018 C5 of Year Finalist
St. Jude Donor '14,'18
I bought the chrome inserts for underside of the hood. Had the paint shop paint and clear the underside. Hasn't affected the paint and it's many years.
DaDuck (12-09-2016)
As always....this forum is a great sounding board for discussion.
I am going to remove the hood blanket and if I do not notice a big increase in engine noise....probably leave it off.
I did notice that the paint around the edges of the blanket on the underside of the hood is rough and thin.
Thanks for the input!!!!
Dave
Dave
I just wrapped my stock insulator several years ago - DD and still looks like new...
Ultimately though it will have no serious adverse effects with it off, such as paint, heat, or sound issues out of the norm, but with it off you will lose this fire suppression ability.
DaDuck (12-10-2016)
Mine was pretty ratty looking when I got the car 5 years ago. I removed it, it wasn't painted completely under it, mostly just primer. I ended up removing the hood, taping off the outer 1/2" and spraying it flat black to match the trunk. Love the way it turned out. I keep a can of fire extinguisher in the car too.
I bought a brand new hood liner from GM auto parts, through my local Chevy dealer. It took 3 days to get it free shipping and it was on sale for $125.00 I like the new look.
