Anybody else have a solid feeling factory shifter?
Old 01-11-2017, 06:03 PM
C5Txfan
C5Txfan's Avatar
Originally Posted by Sam Handwich
heh, heh, heh ..... he sure showed us
Yep seems so ... guess we need to start calling it a 'lever' instead of a 'shifter' then ????
Old 01-11-2017, 06:48 PM
dbgoodwin
dbgoodwin's Avatar
Originally Posted by grantv
That's the whole thing... my shifter is definitely not loose, wobbly, rubbery. It is direct, IMO precise, and takes some effort. It is far beyond my BMW shifters in precise feel.
My car is off the road but I'm going to shoot and post a dry shift video tonight.
Well there's your problem. Comparing the two, the corvette shifter will be a ton better. That doesn't make the corvette shifter good, its just like going from my 92 toyota pickup to my wife's 05 corolla. The corolla isn't fast, but when you compare it to the pickup it's a rocket.
And a lot of people will reiterate the same "The slop isn't in the shifter its in the transmission" because that's what they've heard. While it is somewhat true, the difference in leverage minimizes the feel of the slop greatly, which makes the slop a non-issue with a better shifter.
Again, not to say that there's something inherently wrong with the stock shifter, but a couple hundred bucks and 15 minutes to install it can make it 10 times better, so why not?
Old 01-11-2017, 06:49 PM
dbgoodwin
dbgoodwin's Avatar
God forbid someone (literally read my previous post) call the transaxle a transmission
Old 01-11-2017, 07:38 PM
Dave concrete
Dave concrete's Avatar
The factory shifter is tight, accurate, than you installed an aftermarket shifter and realize how ridiculous the factory shifter was.
The following 2 users liked this post by Dave concrete:
Pounder (01-11-2017), Quickshift_C5 (01-12-2017)
Old 01-12-2017, 11:15 AM
Darrell98
Darrell98's Avatar
I went with the C6 shifter in my 1998, I like it much better.
Old 01-12-2017, 11:37 AM
Roddy13
Roddy13's Avatar
Mine's got a pretty ideal feel to it too, I have no idea what others are talking about with it being sloppy.
A bit of a longer than needed, but whatever.
Old 01-12-2017, 01:29 PM
Quickshift_C5
Quickshift_C5's Avatar
Exactly right. As always, ignorance is bliss.
Old 01-12-2017, 01:42 PM
Roddy13
Roddy13's Avatar
Could be. I know I installed one of the MGW shifters in my Viper and I just shudder at the thought of that shifter. Awful. Like toggling a switch. But everyone loves them. I couldn't bare to have that in the C5... I wish there was a happy medium upgrade. Slightly shorter throws, slightly better angle etc...
Old 01-12-2017, 01:48 PM
Dave concrete
MGW is what I have, it just feels more like it is in gear, like a switch, thats a good thing Mine you can do adjustment for angle and stiffness.
Old 01-12-2017, 02:43 PM
Koufax
Koufax's Avatar
My stock shifter felt like I was driving a truck. I had the MGW installed. Initially, it was too hard to shift, so I had them lengthen it about an inch. (The stick was threaded, so it was easy to let it out some). It's better than stock, but it's not way better. I'd prefer something smoother, but I'm too much of a klutz to try the anti-venom mod and am happy enough with things the way the are to focus on other things.
Old 01-12-2017, 02:51 PM
chasboy
chasboy's Avatar
Oldtimer
Sandy! The anti venom mod is as close to klutz proof as one can get. Don't be afraid of it! I've done it twice, one washer each time.
Old 01-12-2017, 03:01 PM
Pounder
1/4 mile/AutoX
Support Corvetteforum!
Pounder's Avatar
Received 2,081 Likes on 1,634 Posts
after some miles it becomes butter, I also did one washer in the anti-venom mod.
Old 01-12-2017, 03:03 PM
  #33
Pounder
1/4 mile/AutoX
Pounder's Avatar
just make sure to screw the detent nut in my hand, I was in a hurry and used my ratchet and socket and cross threaded the thing, not fun !!! (my bad)
chasboy (01-13-2017)
Old 01-12-2017, 03:18 PM
  #34
Sam Handwich
Sam Handwich's Avatar
for me the anti-venom mod is no improvement on the factory shifter. Looking forward to going with a shifter upgrade later this year.
Old 01-16-2017, 06:55 PM
  #35
BillD1956
BillD1956's Avatar
Default C6 Z Shifter
Originally Posted by knewblewkorvette
I have no complaints about the stock shifter I have in my 02 (my 98 has the C6 Z06 shifter) but I went ahead (based on forum reviews) and ordered a MGW shifter. Now I just need to get off my butt and install it.
Opinion on C6 Z shifter vs stock? The biggest thing I see wrong with stock C5 shifter is the length of the throw.
Old 01-17-2017, 12:31 AM
  #36
6speedsteve
6speedsteve's Avatar
I shortened my stock shifter 3/4", installed a 1-7/8" custom white ball that sits right at the boot, added one washer for the Anti Venom mod, and overall I have no complaints, on occasion 1st can be a little fussy, and you lose some leverage for reverse, all other gears are very smooth, I have no plans to change it.
chasboy (01-17-2017)
Old 01-17-2017, 09:09 AM
  #37
v8srfun
v8srfun's Avatar
When I bought my Frc it had a b&m shifter in it. I did not like it at all the shifter was obnoxiously notchy and the throws were not all that short. A fellow forum member gave me a factory shifter and I installed it but I was not happy with the way it felt either. I then got out the tap and die set and threaded the stock shifter as far down as I could until it started to flare out and cut off the excess material. The shifter for me is now the perfect length and almost the perfect feel. The only thing I do not like about it is the ruber material that gm used to isolate the upper and lower lever is to soft. I want to remove the soft rubber and somehow get something like polyurethane in there.
To Anybody else have a solid feeling factory shifter?
Old 01-17-2017, 09:21 AM
  #38
DDaaryl
DDaaryl's Avatar
Factory shifter works great, ain't broke so I won't fix it
Old 01-17-2017, 10:58 AM
  #39
MY03C5Z
MY03C5Z's Avatar
For cruising around, daily driving the stock shifter does its job. When racing is when you really notice how sloppy it is. I installed an MGW on mine shortly after I got it, much more solid and precise shifts than the stocker.
Old 01-17-2017, 04:52 PM
  #40
FSJim
FSJim's Avatar
Stock shifters are great, as long as it is a C6 shifter. The best way to go IMO without sacrificing the factory look. Going from a stock C5 to a C6 shifter makes a night and day difference and for sure ups the driving enjoyment.
Quick Reply: Anybody else have a solid feeling factory shifter?
