No BRAKE Lights!
No BRAKE Lights!
Hey guys - had some wok done by my mechanic - private guy. He replaced the PCV valve and the assembly. Apparently it was clogged and the main reason I had some oil leakage. Now the hissing is gone. Got home and now the brake lights don't turn on. All four large rear lamps are out, but the narrow, horizontal lamp above the four is working. Any thoughts as to what he might have disconnected during the repair? They were definitely working before I took it in. Thanks.
To 8VETTE7 point, my turn signals stopped working when my hazard switch went bad, but my brake lights still functioned, PIA to change out. Good luck finding the culprit.
My brake lights stopped working on my car and did the same as your car is doing. It was the hazard switch that went bad an caused the problem. I didn't know they stopped working until i almost got rear ended.
It is usually the hazard switch or the multifunction switch (turn signal stalk). I am currently in a dilemma with no brake lights on the left side. I replaced both and everything works. The hazard switch is the cheaper of the 2 so I would start there first.
