C5 headlight bulbs
C5 headlight bulbs
Can anyone tell me if the higher wattage headlight bulbs are worth the cost of replacement? I see some advertised as 100 watt for high beam and I believe 80 watt for the low beam application. I'm really not looking to do a major (read high dollar) change in my headlights, just thought if the higher wattage bulbs would actually make a difference I'd give them a try. Thanks to all in advance.
You may want to check the laws regarding bulb wattage. Around here 80 and 100 watts are for off road use only, not to mention that you'll be annoying as **** to other drivers on the road.
I went with a combo of 9011/9012, 7500K super whites, and it made a heck of a difference. You do have to modify one of the tangs for them to fit though, but that's a two second job with a Dremel and a diamond wheel. Just use the old bulbs as a guide.
I also upped the wattage on the DRL's (bulb number escapes me now, but I do believe they're 55w), and reaimed them to the same height as the low beams. Huge difference there too. Don't need to use the headlights now until it gets really dark out.
All in all, best mod for improving the headlights on the C5 without spending a ton of money.
Increased bulb wattage may increase the light output. I never read any data on how much improvement increased wattage bulbs provide. But at the wattage your looking at your stock wiring harness may be damaged over time. I'd recommend a high voltage wiring harness connected directly to the battery.
Another been there done that warning - I started down the same path your asking about years back and ended up with a small box of unused headlight bulbs before finally doing the HID conversion.
Good luck with your mod.
I would be interested in the bulb number for the DRL,s if you can find it. Thanks
Totally agree with the increased load on your wiring, charging system, etc. I forgot to mention that in my initial post. Thanks MAC5.
As for the DRL bulbs, they're #885. They come in at 50w. I used the 5000K model. I've closely examined the wiring in my C5 since installing them, and I haven't seen any overheating due to the higher wattage. Still using the original fuse too.
You must reaim the DRL lights to get the full potential though. I used the low beams as a reference. When it gets dark, set up about 15 freet in front of the garage door, and mark the upper edge of the low beam lights with two pieces of tape. Kill the low beams, and now bring the upper edge of the beam of the DRL's to the tape. Oh yeah, you'll need a Torx bit for the adjustment screws.
chasboy (01-29-2017)
What I found with the DRLs is over time, the heat from the (OEM) bulbs eventually melts a hole in the housing. If the bulbs don't blow (common occurrence on mine) then the melted hole allows water in the housing, which both blows the build and corrodes the socket.
Given that experience, I would be cautious about putting in a higher wattage bulb (which will generate that much more heat)
Agree with Carl - are you thinking fog light, but saying DRLs?
Or are you talking the 55 watt LED replacement bulb?
This makes no sense
Sorry, I stand corrected. I mean to say fog lights. Since I keep mine on all the time, I've come to consider them like DRL's. Carl is correct. Thanks!
So, the 885 bulbs are for the FOG LIGHTS. Those you can aim, like I described before.
Apologies for any confusion I may have created.
