Halo LED Problem
Halo LED Problem
I have a problem with one of my LED Halo mod tail lights. The inside LEDs does not come on when I press the brake pedal or put on the turn signal anymore. The oval LED ring is working fine.
Any help is greatly appreciated.
Have you checked for a broken wire on the taillight side. There is one wire that has the turn and brake signal and another that has the halo (taillight) on it.
If the above is not the case, then a component on the circuit board is damaged.
Either way the housing needs to be opened to fix it.
Gary
Gary
Received 19,305 Likes
'20-'21-'22-'23-'24
Sounds like a good option.
Received 3,867 Likes
2015 C5 of the Year Winner
RadioFlyer fixed mine also. Great guy...
