The door window stuck WACK method
Received 1,216 Likes
Yesterday with temps in the 70’s and wanting to drop the top to drive the Vette around, I had the passenger window freeze in the up position issue. So last night went into the archives CF posts and found this one (2007) that I named the WACK method. There may be more but I stopped there.
[EMAIL="https://www.corvetteforum.com/forums/c5-general/1768101-stuck-door-window-easy-fix.html"]
But before I did the WACK method, I checked fuses 30(RD CM) and 31(RD Power Feed) in the passenger side just in case one or both were blown. Both were fine. So I summoned my wife to do the button pushing on the driver's door while I WACKED the door where the post instructed. After 5 WACKS (not lightly), the window moved down. I spent the next 5 minutes exercising the window up and down. I left the window just below the rubber as some have suggested. Although this may be a temp fix, thanks to CF post the window now moves without going into the door panel.
It is a temporary fix - time to order a new regulator.
SG Lou (02-21-2017)
There is another post that shows how to take apart the motor and clean it. If you do it right it will work like new and you dont have to replace the connector for a new motor because its not the same as what you currently have. I did 1 of mine 4 years ago and still works like a champ. Even did it on a buddies Grand Prix window motor and saved him $$ too.
Chris
Chris
Pretty much same thing happened to me yesterday..
https://www.corvetteforum.com/forums...dow-motor.html
Chris
SG Lou (02-21-2017)
https://www.corvetteforum.com/forums...uild-pics.html
You have to make sure you clean/sand the armature really good and then smooth out the brushes along with just cleaning and lubing everything. It really does work and doesn't take that much time. Let us know how it goes.
Chris
Chris
SG Lou (02-21-2017)
In my case, my C5 has been my DD for 16 years and when it locked up the second time, I did not want to risk it getting stuck at the wrong time, so I just replaced my regulator assembly 10 years ago - not "that" expensive or difficult. I replaced the other one on the driver's side last year when it started making a grinding sound. Plus, I don't like "beating" on my car if something is wrong unless it was an emergency.
On the plus side, apparently most of the time they get stuck in the UP position - so at least there is that!
It's wierd how so many people seem to have the same problems the same day, at least we know it must be a common problem though
