Passenger Side Window Motor
Finally got a chance to take out the car yesterday and the passenger window wouldn't work. I'm not gonna mess with banging door panel, etc, etc. Gonna get a ACDelco replacement. No big deal right ?
From what I'm seeing the new replacement unit now require you to also purchase an additional replacement plug/pigtail.
Am I missing something here? What happened to direct plug and play?
Anyone else encounter this during a replacement ?
GM / ACDELCO Part # 15781690
Pigtail # 88988609
http://www.gmpartsdirect.com/oe-gm/15781690
http://www.rockauto.com/en/moreinfo....sn=540&jsn=540
http://www.gmpartsdirect.com/oe-gm/88988609
Pigtail # 88988609
Advice noted except.....I have already replaced the passenger side regulator on my 03 Silverado twice with aftermarket units...the first one didn't last a full year. Another thing I noticed is the aftermarket units tend to move a lot slower then the OEM unit.
Forum member Spectator2 has a set of used regulators (both sides) just posted for sale for only $50. Might be worth checking out.
SG LOU I just replaced the driver side with a GM AC DELCO and it said nothing about needing the male pigtail. Unless it was worn, I do not see replacing it. I agree about the aftermarket. I replaced the same assembly last year with aftermarket. Never again.
https://www.corvetteforum.com/forums...uild-pics.html
Clean and fix what you have. Its cheaper and will probably last longer and you wont need to change the wiring connector if it is truely a new replacement motor.
Chris
Chris
SG Lou (02-21-2017)
