Advice on a knock sensor error
Ok, so 2004 Verte, Base, 5.7L, great auto, low mileage only 25K. So over the winter I didn't run it much at all, I am in Missouri, high humidity most of the year. So during the winter months it posted a P0332 (rear knock sensor) only, with once in a while it would throw the MIL. So, now after two long trips the error has not posted at all. I am running the high tier 91 Octane (all I can get here), is it possible I got a tank full of bad gas that is now purged? I understand you can't diagnose it over the net, but in your humble opinions, do you think I should go ahead and replace both of the knock sensors? Or wait to see if it posts again? Thanks.
