Can you change oil filter without draining the oil?
When you change the filter without changing the oil, will all the oil drain out the filter fitting or is it just the amount in the filter??
Some technical articles have recently indicated the weakness with the supersinthetics is the filter.
MONARTOR
why??
Originally Posted by Patches
Yes, you can. I routinely take the oil filter out during header installs and I do get a little spillage because the filter is full but I only lose 1/4 qt. at most.
Originally Posted by madeouttaglass
Patches, How often do you change your headers? Sounds like you get less miles on them than you do your oil. Interested in selling me some of your old ones cheap?
Received 19,282 Likes
'20-'21-'22-'23-'24
You can take the filter off without draining all the oil. That is the first step I take when changing both the filter and the oil. Only oil that comes out is what is in the filter.
Received 1,674 Likes
Originally Posted by Grumpy
why??
1 Post
CI 4-5-6-7-8 Veteran
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-16-'17
As for the oil filter, you can remove it without draining out all the oil... or should I word it that it can be removed and all the oil won't come rushing out.
Let me clarify that... you can remove the filter and all the oil in the car won't come rushing out as long as you don't start the engine while the filter is off. (I hope no-one would do that, but ya never know :bb )
Originally Posted by Rogue Wave
You shouldn't change your headers until the DIC shows Header Life Remaining is below 10%. Otherwise you are just wasting $$$$.
1 Post
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
...Now back to the question...why?
Why? If you can afford a Vette, then why not do the cheap insurance by changing the oil every 3K? Thirty some bucks every 3K provides some peace of mind, and synthetic oil gets dirty just like regular oil, so that is also why I still change it every 3K.
Richin Chicago has the link to an ongoing experiment with the supersynthetic oils (Redline, Amsoil, Purple) and Mobil 1 as well. I'll try and find it and post it.
The findings in the experiment are indicating that the filter wears out before the oil does. You can get 10,000, 15,000, or more out of these oils, even Mobil 1. The filter needs changing much earlier. Speaking out of my a$$, without rereading the article, the filter lasts between 5k and 8k.
I'll try and get that link.
And for all those that like changing their oil every 3k just to be safe...well...go right ahead...it doesn't need to be.
http://neptune.spacebears.com/cars/s.../oil-life.html
I guess I shoulda' been a little more clear on that. A buddy and I did mine and I have helped install a few others on friends' cars as well.
More informatione on filters can be found here.
Oil Filter Study
I just changed my filter, from a UPF-44 to a Baldwin. Oil pressure is higher and no more ticking on start-up.
Oil Filter Study
Oil Filter Study
Oil Filter Study
