Any tricks for changing battery in a 2000 ?
I am going to a gel battery to replace my oriiginal battery in my 2000. Anything I should do or plan for or do i just unplug and replace?
MONARTOR
out with thold, in with the new... you might have to reset the clock
1 Post
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
I just did this. You need a wrench to reach the side terminals of the battery (Auto Zone has them and other places if you don't have one or something else to use). Try not to drop anything like bolts and such under the battery 'cause they're hard to get out and rattle around. I had to reset my clock. Other than that I removed an AC Delco and put in an Optima in no time.
CI III & IV Vote Ho
CI II, III, IV & V Vet
CI IV Bracket Champ
St. Jude Donor '03-'04
Originally Posted by lager99
That's years of experience talking...
Get the 9 volt battery adaptor that fits in the cigarette lighter and you don't have to reset anything. Also, make sure you get the GM tie down clamping bracket that goes with the Optima battery.
Its a little known fact but in order to change a battery...and this is for the 2000 models only, you have to do it only during a full moon and on the 3rd thursday of only the even numbered months.
The actual removal of the battery cables must be done with a pair of vice grips blessed by a voodoo shaman. Now you could probably do the whole thing the old fashioned way and skip all of the above steps, but if it goes wrong you have nobody but yourself to blame. Good luck!!
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
Originally Posted by Mean Green
It's a freakin' battery for God's sake
Received 19,282 Likes
'20-'21-'22-'23-'24
You may have to unlock your radio if you have the theft lock activated, but that is about all.
Disconnect and the positive (red) terminal first, and reconnect it last. Make sure that the alarm system isn't on when you disconnect the old battery otherwise the first thing that you will hear is the alarm going off when you put the positive terminal back on.
BTW, corking avatar lager99.
