what does a 2000 convertible a4 weigh
Old 01-13-2005, 11:55 AM
racerrob333
Support Corvetteforum!
racerrob333's Avatar
Default what does a 2000 convertible a4 weigh
how much does a 2000 convertible a 4 weigh???
Old 01-13-2005, 12:30 PM
talon90
talon90's Avatar
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
The Curb Weight is 3248 lbs. (I'm not sure about the differentiation for A4 vs. MN6) Someone else can chime in here but there is a 2 pound difference from the coupe and a .1 pounds per horsepower ratio between the A4 vs. the MN6. So, if my calculation is correct ((9.4*345)-(9.3*345))=34.5 lbs so approximately a 34 pound penalty to the A4. Please someone help me if I've done this wrong.
http://www.corvetteactioncenter.com/...2000specs.html
Paul
Old 01-13-2005, 12:33 PM
0EG@EnglandGreen
Supporting Tuner
EG@EnglandGreen's Avatar
Location: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Answer is in the sticky at the top of C5 General
Old 01-13-2005, 01:39 PM
talon90
talon90's Avatar
NCM Ambassador
EG, if you could point me to it I'd appreciate it. I want some validation on the equation above....problem is I've looked and looked in the sticky and the specific answer is not in there. The closest I could find was the difference of the Engine / drivetrain combo of 39.6 lbs. If that's it then I'm satisfied with my "gross" calculation.
"457.6 lbs, LS1 auto; 497.2 lbs, LS1/LS6 manual --- LS1/LS6 dressed --- Source"
It also appears that the sticky does not list the curb weight at all, which was a big part of the original poster's question. Did I just miss it? If so, the drinks are on me when we get together in the spring!
Paul
To what does a 2000 convertible a4 weigh
Quick Reply: what does a 2000 convertible a4 weigh
