2004 c5 Preliminary Information FYI
2004 Chevrolet Corvette - Preliminary Information
Select a document to view:
#PIT3353 All General Motors Passenger Cars, Trucks and Utilities Use of Star Washer on a Body or Chassis Ground - kw wire connector terminal starwasher star washer - (Jan 7, 2005)
#PIC3323 97-04 Chevrolet Corvette Easy Exit Feature Explanations - kw 5.7 electrical LS1 LS6 memory operation part performance power pump seat - (Jan 6, 2005)
#PIP3096 Calibration Update Information for Different Tires and Rear Axle Ratios on 02 Pontiac Firebird, 02 Chevrolet Camaro, 03-05 Corvette and All 96-05 Trucks, Vans, Utilities- kw automatic axle PCM pinion - (Dec 22, 2004)
#PIP3257 97-05 Chevrolet Corvette 4L60E/4165E P0894/P1870 After Ring and Pinion Replacement kw aftermarket axle converter DTC gear repair slip transmission P1870 P0894 - (Dec 7, 2004)
#PIC3273 97 - 04 Chevrolet Corvette System Message on DIC after Alternator Replacement - kw battery charge electrical generator IPC lamp light message MIL - (Dec 3, 2004)
#PIP3136 4L60E , 4L65E Slip Condition in 2nd , 3rd or 4th Damaged 2-4 Band 3-4 Clutch - kw automatic band bind body busy chatter clutch fourth GTO second shift shudder slip third transmission valve PQC - (Nov 30, 2004)
#PIP3140 Abnormal Noise and Vibration While Driving - kw accessory aftermarket axle buzz case growl groan howl moan prop rattle resonance shaft transmission whine body boom part modification no OEM - (Nov 24, 2004)
#PIP3237 97-04 Chevrolet Corvette 700 - 900 RPM Buzz, Moan, Rattle, Resonance Noise on Acceleration - kw 5.7 LS1 LS6 Z06 absorber accelerate axle bracket damper differential exhaust insulator launch mount turn - (Nov 16, 2004)
#PIP3170 4L60E M30 , 4L65E M32 Harsh 1-2 Shift - kw automatic first noise second shift hard PQC - (Oct 4, 2004)
#PIP3002C 4L60E / 4L65E Intermittent Neutral from a Stop or 2-3 Shift - kw flare information launch slip - (Sep 22, 2004)
#PIP3106 4L60E/4L65E Snap Noise 2-1 Downshift - kw 136 149 233 236 246 4L60EHD automatic bind clash clunk drive engage grab hard harsh second shift - (Sep 22, 2004)
#PIP3146 Crank, No Start When Cold Due to Compression Loss - kw cylinderhead extended hard lifter loss - (Sep 17, 2004)
#PIP3144 P0101 , P0106 , P0121 Poor Acceleration and Detonation in Gear - kw 2.2 2.4 3.1 3.4 3.8 4.0 4.2 4.3 4.6 4.8 5.0 5.3 5.7 6.0 6.5 6.6 7.4 8.1 3L30 372LE 4L60E 4L65E 4L80E 3T40 4T40E 4T45E 4T60E 4T65E - (Sep 16, 2004)
#PIT3173 All 1995-2005 Passenger Cars and Trucks Information on Testing Centers for Fluid Contamination - kw brake coolant fluid fuel gasket gear hydraulic leak oil part porosity power seal specification - (Sep 16, 2004)
#PIC3144 97-05 Chev Corvette, 97-02 Chev Camaro and Pontiac Firebird Slight Pull Left or Right, Tire Wander - kw air alignment pressure ride steering suspension - (Sep 16, 2004)
#PIT3154 All GM Vehicles Using Class 2 Communications Diagnostic Strategy for DTC U1000 or U1255 - kw BCM code EBTCM radio RIM - (Sep 10, 2004)
#PIT3117A 2004 Chevrolet Corvette Driver or Passenger Seatbelt Will Not Release from Retractor - kw seat belt restraint information - (Sep 3, 2004)
#PIC3118 Wind Noise or Water Leak at Top of Door Glass - Adjustment Tips - kw adjust air convertible door fit gap glass moisture noise pillar position seal water weatherstrip whistle - (Aug 26, 2004)
#PIC3117 04 Chevrolet Corvette Drivers or Passengers Seatbelt Will Not Release from Retractor - kw belt seat information - (Aug 26, 2004)
#PIC3062A Supplement to 00-00-89-027B Eliminating Unwanted Odors in Vehicles - kw information park smell water wet leak - (Aug 25, 2004)
#PIC3110 93-04 Chevrolet Camaro/Pontiac Firebird/93-05 Chevrolet Corvette Muffler Paint Peeling Supplement to TSB 33-17-01A - kw body chip dirt exhaust hanger tailpipe - (Aug 19, 2004)
#PIC3100 Odometer Accuracy - kw inaccurate cluster speedometer - (Aug 19, 2004)
#PIP3104A 97-05 Chevrolet Corvette 6-Speed Shifter Rattle Growl Buzz Noise - kw 5.7 6sp boom clash clutch diagnostics gear late lazy LO4 LS1 manual MM6 MN6 M12 neutral noise pinion rattle shake shift shifter - (Aug 18, 2004)
#PIT3099 00-05 All General Motors Light Duty and Passenger Cars Questions Regarding Installlation of Dealer Installed Accessories - kw part GMT355 GMT360 GMT368 GMT370 GMT600 GMT800 GMT805 GMT806 GMT820 - (Aug 4, 2004)
#PIC3060 Key Code Lookup - kw cut information - (Jul 19, 2004)
#PIC3031A Service VME - Updates to SI and the PI Numbering Process - kw information - (Jul 15, 2004)
#PIP3060 4L60E ( M30 ), 4L65E ( M32 ), Stationary TCC or P1870 Diagnostic Test - kw P0894 DTC clutch converter solenoid transmission valve slip shudder shift automatic - (Jul 12, 2004)
#PIP3056 97-05 Vehicles with 4.8 5.3 5.7 and 6.0 Gen III V8 Engines and Misfires on One Bank - kw CEL diagnostics driveability DTC P0171 P0172 P0174 P0175 P0300 P0301 P0302 P0303 P0304 P0305 P0306 P0307 P0308 - (Jul 12, 2004)
#PIC3032 97-05 Chevrolet Corvette Low Oil , Low Fuel , or Temperature Indicator Displayed on the Heads Up Display - kw body cluster coolant electrical fuel gas gauge HUD hot IPC inoperative LS1 LS2 lamp light - (Jul 5, 2004)
#PIP3025 04 Model Year 4.8 5.3 5.7 6.0 GENIII Engine Piston Pin Information - kw accelerate cold crank crankshaft cylinder L59 LM4 LM7 LQ4 LQ9 LR4 LS1 LS6 mechanical motor piston GMT800 GMT820 GMT830 - (Jun 24, 2004)
#PIT3027 In-Line A/C Filters from Bulletin 01-01-38-006B Are No Longer Available - kw ac air condition HVAC - (Jun 23, 2004)
#PIP3018 4.8 5.3 5.7 6.0 GENIII Engine Cylinder Head Cup Plug Coolant Leak - kw coolant cup head L59 LM4 LM7 LQ4 LQ9 LR4 LS1 LS6 plug - (Jun 17, 2004)
#PI02146 5.7 LS1 4L60E Automatic Transmission Oil Pan Leak - kw bolt cooler gasket line repeat fluid - (Jun 2, 2004)
#PI00722A Remote Keyless Entry Interference; Use of J43241 Fob Tester - kw accessory key performance poor program RKE - (May 28, 2004)
#PI02135 In-Line A/C Filters from Bulletin 01-01-38-006B Are No Longer Available -kw air condition HVAC - (May 27, 2004)
#PI02057A SPS Programming Concerns - kw cluster DDM communication ECM PCM EBTCM TCCM TCM IPC L18 L30 L31 L35 L36 L37 L52 L61 L67 LA1 LD8 LF6 LG8 LK5 LL8 LM4 LM7 LN2 LQ4 LR4 LS1 LS6 LU3 LGM module program PDM - (May 6, 2004)
#PI02018 Red OnStar LED , No Keypad Response When Pushed DTC B2476 - kw inoperative UE1 - (Apr 22, 2004)
#PI02001 4L60E , 4L65E Transmission - New Design Oil Pump Seal (Oil Pump to Case ) - kw automatic leak oil DTC slip shift - (Apr 15, 2004)
#PI02000 Low or No Oil Pressure on 2004 LS6 Engines - kw 5.7 light - (Apr 15, 2004)
#PI01624A Service VME - 4.8 5.3 6.0 LM4 LM7 LR4 LQ4 LQ9 GEN III Engines with MAF Sensor Code P0101 - kw driveability fluctuation idle intermittent MAP rough stall surge hesitation - (Apr 5, 2004)
#PI00822C 4L60E , 4L65E No 2nd , No 4th and No Reverse - automatic fourth second shift transmission - (Feb 20, 2004)
#PI01714 4L60E M30, 4L65E M32 Transmission - Leaking and/or Broken Trans Case at 2-4 Servo Cover - kw automatic clutch drive first fourth gear leak no noise oil reverse second shift third PQC - (Feb 5, 2004)
#PI01657 Clarification of ABS-Related Option Codes - kw active brake caliper disc DTC EBTCM light MIL module sensor steering SWPS TCS part - (Feb 2, 2004)
#PI01659A Service VME - Intermittent or Inoperative Fuel Gauge - kw 5.7 dash display electrical ground inaccurate indicator information IPC LS6 LT1 operation panel performance sensor short - (Jan 29, 2004)
#PI01599 4L60E, 4L65E Forward and Low Reverse Waved Steel Clutch Plate Appearance Change - kw appearance chatter first fourth PQC second shift shudder slip third transmission valve - (Dec 23, 2003)
#PI01591 Replacement Batteries for 2004 Corvette and XLR - kw 4.6 accessory battery body charge crank dead DIC electrical gauges generator ground ignition indicator information inoperative instrument IPC lamp - (Dec 16, 2003)
#PI01006 Platform Battery Drain Diagnosis Process - kw accessory aftermarket battery BCM charge code connector consumption corrosion crank diagnostics DIC display DLC DTC electrical fuse gauge generator hard - (Dec 11, 2003)
#PI00110A Fuel Gauge/Pump Diagnostic Tests - kw 4.6 5.7 01-06-04-022 01-06-04-010A battery cluster display DTC gas inaccurate inoperative instrument intermittent IPC light LH2 LS1 LS6 P0461 P1431 P2636 P2066 - (Dec 9, 2003)
#PI01498 Transseal Temporary Protective Coating Removal Instructions - kw adhesive appearance damage glass hatch leak moisture panel rear roof seal water weatherstrip wet window windshield - (Nov 10, 2003)
#PI01483 Vehicle Has No PCM Communication with Tech 2 - kw ALDL APP code LM4 LM7 LQ4 LQ9 LR4 - (Nov 4, 2003)
#PI01418 Service VME - Blotches in All Glass - appearance display door front information light rear windshield - (Oct 8, 2003)
#PI01363 Rear Axle Side Cover Oil Leak - fluid leak seal repair - (Sep 12, 2003)
#PI01358 OnStar Remote Functions Operational Check - antenna blue cellular communication data electrical GPS horn inoperative lock operation remote signal SMU telephone UA1 UE1 VCIM VCU VIU weak - (Sep 11, 2003)
#PI01337 GPS Connector Will Not Connect to New Module - cellular coax DTC electrical identification inaccurate information inoperative light lock OnStar part signal SMU VCIM VCU VIU - (Aug 28, 2003)
#PI01320 Service VME - Brake Squeal and Brake Dust Accumulation - ABS TCS wheel - (Aug 18, 2003)
#PI01231 Service VME - Wheel Damage from the 1/4-Ounce Wheel Weight - chrome pressure suspension TPM tire valve test format - (Jul 10, 2003)
#PI00990 Windshield Washer Nozzle Leaks on Windshield - appearance bleed check clearance damage fluid leak valve wet water window - (Apr 14, 2003)
#PI01003 Service VME - Heater Air Conditioning ( HVAC ) Control Head Does Not Respond - DTC electrical - (Apr 9, 2003)
#PI00280 Service VME - Wind Noise from Upper B Pillar Area - (Jul 25, 2002)
#PI00057 Hardtop Water Leak into the Rear Compartment Area - (Jun 21, 2002)
#PI00054 Rear Lift Window Hatch and Roof Bow Panel Fit Concern - (Jun 21, 2002)
#PI00048 Convertible Top Stowage Compartment Lid Not Flush with Quarter Panels - (Jun 19, 2002)
#PI00043 DIC Onboard Diagnostics Show DTCs U1016, U1064 and U1096 in History - (Jun 19, 2002)
[HOME] [PUBLICATIONS]
[NUMBER SEARCH] [LATEST NEWS] [BULLETIN SEARCH] [FEEDBACK] [HELP]
2004 c5 corvette TSB to date.
2004 Chevrolet Corvette - Bulletins - Technical
#03-08-44-005C Poor Radio Reception or Radio Static/Increased Interference with Rear Window Defogger On or Some Rear Window Defogger Grids may be Inoperative (Diagnose and Repair Rear Window Defogger Heating Grid) - (Jan 19, 2005)
#02-07-30-013C Incorrect Transmission Shifts, Poor Engine Performance, Harsh 1-2 Upshifts, Slips 1ST and Reverse, Torque Converter Clutch (TCC) Stuck Off/On, DTC P0730, P0756, P0757, P0741, P0742 - (Jan 3, 2005)
#00-07-30-022C No Reverse, Second Gear or Fourth Gear (Replace Reaction Sun Shell with More Robust Heat Treated Parts) - (Dec 10, 2004)
#01-07-30-032B Transmission Oil Leaking From Transmission Vent (Replace Transmission Case Cover Gasket/Channel Plate Gasket) - (Nov 18, 2004)
#02-06-03-006B No Start, No Crank, Battery, Batteries, Generator, Gages, SES, SIR, Brake, Security, Theft, ABS, Hot, DIC Messages, Lamp, Light, Battery and Generaotr Diagnostic Testing and Cadillac Roadside Service, - (Nov 10, 2004)
#01-07-30-002D Malfunction Indicator Lamp (MIL) On, Transmission Stuck in Second or Third Gear, Instrumend Cluster Inoperative (Replace Ignition Switch) - (Oct 19, 2004)
#04-07-30-033 No Reverse Hot, Transaxle Slips in Reverse When Hot, Bump in Reverse Hot (Retighten Valve Body Bolt (379) and Replace Channel Plate Gasket) - (Aug 4, 2004)
#04-07-30-025A Transmission Fluid Leak, Inoperative 2nd/3rd/4th Gears, No Movement, Case Cracked or Broken at 2-4 Servo (Repair Transmission and Install New Retaining Ring) - (Jul 27, 2004)
#01-03-10-009A Plastic Wheel Nut Covers Missing and/or Loose (Replace Missing Covers and Add Sealant to All Covers) - (Jul 27, 2004)
#04-08-51-003 Rear Hatch Surface Blistering (Replace Hatch) - (Jul 20, 2004)
#04-07-30-028 4T65-E Automatic Transmission Fluid Leak From Reverse Servo Cover (Replace Reverse Servo Cover and Seal) - (Jun 15, 2004)
#04-06-05-006 Jingling Noise on Deceleration or Coast Down (Section and Replace Intermediate Exhaust) - (Jun 15, 2004)
#04-06-04-031 Vehicle is Difficult to Fill with Fuel or Filling Station Pump Shuts Off Before Tank is Full (Replace Tank Filler Hose) - (Apr 22, 2004)
#04-08-50-005 Seat Back Twisting (Resynchronize Seat Back Recliner) - (Feb 26, 2004)
#01-07-30-038B DTC P0757 Set, SES Lamp Illuminated, Poor Performance of Transmission, Transmission Slipping (Clean Transmission Valve Body and Case Oil Passages of Debris) - (Jan 26, 2004)
#03-04-20-006 Fluid Leak at Rear Axle (Replace Left Differential SIde Cover O-Ring and Left Axle Shaft Seal, Add Sealant to Side Cover Flange) - (Nov 18, 2003)
#03-08-42-012 Twilight Sentinel/Automatic Headlamp Control Not Functioning Correctly or is Inoperative (Reprogram BCM) - (Nov 18, 2003)
