C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
Thermostats and tune - general (dumb?) question.
Old 04-08-2005, 07:50 AM
zulatr
zulatr's Avatar
Default Thermostats and tune - general (dumb?) question.
I have an 03 Z06 that I bought with a predator tune. In a thread from yesterday it was stated that the car should have a 180 degree thermostat.
My car is running at an indicated temp of 213 under light load on a 70 degree day, so is it correct to assume that I have a 210 thermostat?
Looking at the car, it looks like the thermostat is in the lower radiator hose instead of the upper hose like all the other small blocks I've had. Is the thermostat under the cover on the lower hose?
Any recommendation on a manufacturer for a new thermostat?
Old 04-09-2005, 12:16 AM
Dirty Howie
Dirty Howie's Avatar
Mine runs at 192-196.....stock stat.
Old 04-09-2005, 11:01 AM
lvvette777
lvvette777's Avatar
Your stock thermostat would be 192 and I don't think they even make one hotter than that. I would say if yours if running that hot your thermo might be getting ready to fail.
One question, when you say you are running 213 degrees under light load are you doing at least 45MPH? If you are moving 45MPH or over your temp should be down around 190-195 degrees. If you are sitting in traffic and relying on the fans to cool you off don't be surprised to see temps in the high 220's.
Old 04-09-2005, 10:50 PM
Dirty Howie
He should check for debri blocking his radiator too.....
Old 04-23-2005, 02:05 PM
David426
David426's Avatar
use 180 stat or 160
Old 04-23-2005, 09:01 PM
MDriveMode
Support Corvetteforum!
MDriveMode's Avatar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
I use an SLP 160 and run about 178.
Old 04-23-2005, 11:56 PM
vetred
vetred's Avatar
any hotter?????? there are simply none, zero, no, nill, zip, benifits to running it any hotter
To Thermostats and tune - general (dumb?) question.
Quick Reply: Thermostats and tune - general (dumb?) question.
