hptuners and larger injectors
I plan on running larger injectors to support a larger (100-150) dry shot. Is there and injector constant or setting for the corvettes that I can change and have the car run exactly the same with the larger injectors? Im worried about effecting the manners of the car as it sits stock.
Former Vendor
the ifr table affects everything from idle, part throttle & wot...depending on how large the injectors are it may or may not be a one & done type of adjustment. The larger the injector the harder it is for the computer to compensate for idle pulse widths & such.
the same way people a retarding timing... im assuming there is a fuel table vs MAF where i can add fuel for higher airflow rates which those cells will only be hit on the bottle. if this wont work let me know
I run N20 wet, and use the IAT table, with a little harness I make for it, and it works flawlessly, but right off the top of my head, can't think of a solution to add enrichment on demand, without screwing something else up. Spraying nitrous on the hot wire always has been, and is a bad idea, but I'm not sure that's what you are meaning here. Anybody else tried this?
St. Jude Donor '13-'14-'15
larger injectors
YES---when you install differnent injectors you need to change the "injector flow rate " table in the ECM--The current table is also usually scaled--for example say you have stock 26 lb injectors, at high vacuum they may start at 27 lbs and are scaled down to 25 lbs at low vacuum (WOT).Just follow the same scaling they did. If you do nothing and installed 30 lb. injectors and you car came with 26's then you fueling will be extremly rich--(Having a number smaller in the ECM then what is actually in there , makes it rich---and vice versa)--A larger number in the ECM than what is in there makes it lean---This of corse is in open loop or power enrichment (WOT) only.
At part throttle, the 02's will try to get you an AFR of 14.63 no matter what you have installed--However it can only adjust so far and it will throw a code and stop adjusting
