HP tuners Pro: turn off knock sensors?
Hi guys!
My car runs pretty bad and I am getting the P 0327 code which concerns the knock sensor.
Before getting a new one, I'd like to check if the driveability issues go away when they are turned off.
Can it be done? If so how do I do it?
Sorry or the newb questions, I am still learning the software!
St. Jude Donor '13-'14-'15
With My EFILIVE I took a look and couldn't find any single table that would disable the knock sensors---However--I found 49 tables in the knock retard file !!!! Really a huge file---My guess would be the knock sensitivity table and the knock frequency table would be a good starting point-I 've used these to get rid of false knock before and they worked pretty well--not sure about how to entirely delete KR or if i would even do it----
Just go into your max kr table and set everything to zero then load the file. At least then the sensor will not pull any timing since the table is zeroed out.
Jer.
Jer.
Good info
