C2120 TPM Code Question and some others
Hey guys, my car (a 1998 6spd vert) is throwing a current code of C2120 which I believe is the tire pressure monitor system. How do I fix this/eliminate the code, I don't really care if this system works or not.
This is a "current" code but I have several other "H" codes as well which are listed below.
B0851 Battery 1 Out of Range
B2262 Horizontal Position Sensor Circuit
B2264 Vertical Position Sensor Circuit
B2282 Battery #1 Circuit
B2285 Battery #2 Circuit
C1281 Steering Sensor Uncorrelated Malfunction < - This seems imp.
U1016 Loss of Communication with PCM
U1064 Loss Communications with BCM
U1096 Loss of Communcations with IPC
I would really appreciate some comments on this
Also, how do you clear codes?
Also just to note this. I'm having an odd problem with the speedometer that I have previously posted.
My speedometer constantly shows 5 to 7mph slower than the speed that is indicated by the DIC as the cruise speed. This speed (indicated by the DIC) has been GPS verified and is correct but like I said the speedometer is wrong. Could some of this cause this?
Did you get a response?
I was wondering if you ever got a response on this or how you resolved this issue -got the same TPM codes
Yellow '01
